Correct Sub Box Size calculations
Old Jan 23, 2002 | 09:52 AM
burrll_gee's Avatar
Ok i have 2 Pioneer 12" diamondplate TS-W303C speakers
reccomended volume is 1.5 CF according to Pioneer's website.
How can i build my own box and get the dimensions right?
Im going for a trapazoid shape right behind the rear seat of my 95 4thgen How can i get measurements perfect?
BG
PS. Ive searched but havent found quite what im looking for.
Old Jan 23, 2002 | 11:26 AM
gotmilk2000's Avatar
the jl audio site has a box dimension format and calculator on it
Old Jan 23, 2002 | 08:30 PM
jmax
(length of base + length of top)/2 X depth X height
What ever the shape, just use your geometry and trig rules. If you have a complex curve you may have to use some calc, or estimate. There are also a lot of tricks to estimating.
Old Jan 23, 2002 | 09:19 PM
burrll_gee's Avatar
do you mean
top width(front to back)+bottom width(front to back)
--------------------------------------------------- divided by
2x length(side to side) x height(top to bottom)
Assuming top and bottom are parallel?90 angle corners ?
TopWidth
H | \ What about the face?
| \ how do you calculate the height?
|___________\
{bottom width}
Length of base?
Old Jan 25, 2002 | 07:52 AM
jmax
I meant what I said. That is for a traditional trapezoid with parallel top and bottom. The only differnce between the top piece of wood, and bottom piece of wood, is the width. Height is a strait line, measure with tape measure. Actually, these are all strait lines. The face, all you need is the height. Since width is determined by (width(1) + width(2)) / 2
Remember, volume is L X W X H. Width of bottom and top are different in trapezoid, so use the formula for average width.
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
leatherneck
Sep 30, 2015 09:16 PM
Sep 27, 2015 08:37 AM
