box size help
Old Jan 27, 2002 | 07:26 PM
hockeyghst's Avatar
box size help
ok i am gonna get 2 12" Hx2's what size box do i need so these subs will sound at their best....should it be ported or sealed???? i want to ge the most bass as possible so i wanna know if sealed or ported is better.....thanx guys i appreciate your help/advice thanx again, Tom
here is some info
Product Features:
Dual 4 Ohm voice coils
CONsealer gasket hides mounting screws and prevents air leaks around the frame
Frequency response 26-200 Hz
Power range 150-500 watts RMS (250 watts per voice coil)
Peak power 1,000 watts
Sensitivity 88 dB SPL
Top mount depth 5-13/16"
Sealed box volume 0.8-4.0 cubic feet
Ported box volume 1.75-4.0 cubic feet
links are greatif u know a site which has a box for these subs....
Old Jan 28, 2002 | 06:49 AM
jmax
Ported will be louder than sealed. Email the manufacturer ( is that RF? ) for recommeded box volume and port dimensions for high SPL system.
Old Jan 28, 2002 | 08:17 AM
hockeyghst's Avatar
yeas it is rockford fosgate.....i want a box that will give me the most bass possible.....i take it that a ported box is what i need....thanx guys
Old Jan 28, 2002 | 03:02 PM
hockeyghst's Avatar
so which one is it??? ported or sealed???? i want the most bass possible!!!! thanx guys, Tom
Old Jan 28, 2002 | 09:04 PM
jmax
Let me explain this in a little more detail. RF is a mega money manufacturer. They have the dough and the engineers etc. and LEAP software. So email them for the recommended box volume and port dimensions. You hear it that time, email RF. Make sure you make it clear to them that you want an SPL system.
Old Jan 25, 2003 | 08:04 AM
Nore474's Avatar
I was wondering the same thing does it matter if you make the ported box bigger then the requirments?
and whats the difference between a bandpass and ported?
Old Jan 25, 2003 | 08:25 AM
jmax
As I said earlier, ported will generally be louder than sealed. Depending on the frequency you tune it to the sound quality could be as good as or much worse than sealed. Same for power handling. If you make it bigger than recommended it becomes more efficient but you must adjust the port dimmensions appropriately for the desired tuning frequency. Also when you make any box bigger a sub becomes more efficient which means that you need less power to achieve the same excursion. Power handling decreases.
Bandpass uses two seperate chambers and the sub is completely concealed. All the soundwaves that you hear are produced by the interaction of the sub, the chambers and the ports. In other words there is no direct radiation of soundwaves from the driver to your ears. They can be difficult to tune, but done properly can be very rewarding. One drawback other than the high probabillity of mistuning is the large box size.
For max SPL without losing all SQ I would use ported. Tuned as low as practical. But I would keep in mind the lowest frequencies that my music tastes represent for the sub. For me that would mean tuning at 25 hz or less. For the average hip-hop, rap, R&B listener tuneing to 30-35 hz would be plenty low. In either case I would use an infrasonic filter set 5-10 hz below the tuning frequency.
Old Jan 25, 2003 | 09:52 AM
Nore474's Avatar
here are the pics of my setup now notice the small Box
I wanna get a ported box
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
Sep 27, 2015 08:37 AM
