Oh, Maximadave.......
Old Feb 4, 2002 | 01:09 PM
PrinzII's Avatar
OG and counting...
I need prices on the following:
JL Audio 500/5 Amp
Eclipse CH5061 In Dash CD Changer
Eclipse 37601 Balanced Line Adapter
Old Feb 4, 2002 | 01:35 PM
maximadave's Avatar
detailerdaveb@gmail.com
Re: Oh, Maximadave.......
JL Audio 500/5 Amp
You have mail!
Old Feb 4, 2002 | 01:44 PM
PrinzII's Avatar
OG and counting...
Muchas Gracias, Amigo
I'll tell you why I asked in the Email.
Old Feb 7, 2002 | 12:17 PM
PrinzII's Avatar
OG and counting...
Any word on the 37601?
Old Feb 7, 2002 | 01:10 PM
maximadave's Avatar
No word from the rep from Eclipse. Try calling around at other Eclipse dealers to find out. There is not that many where I work.
Old Feb 7, 2002 | 03:45 PM
time2reup's Avatar
MaxmimaDave
I need an in dash crossover and two JL 12s. I have a ZR 240 should I stick with W-0s or will it push the W-3s allright?
Old Feb 7, 2002 | 04:17 PM
maximadave's Avatar
Originally posted by time2reup
MaxmimaDave
What brand is the ZR240?
Old Feb 7, 2002 | 08:41 PM
ny96max's Avatar
The Kicker ZR240 will definitly push x2 12w3's. This past summer before i sold my 240 i had it pushing x3 12w3's in a sealed box, with ease!! BTW i also has x3 4" cooling fans mounted to it to prevent overheating.
Also buy an SMX crossover-module if you dont have on already, and set it at 80hz LP.
As for the JL's, buy the dual 4ohm 12's and wire them series/parallel, this will give the amp a 4ohm load but will actually run the amp down to 2ohm since there is two subs involved.
Peak power from that amp at 2ohm mono is 300watts!! keep in mind that Kicker always under rates their amps by atleast 100watts. Kicker is definitly one of the best amps on the market for bass.
goodluck,
Ant
Old Feb 8, 2002 | 06:11 AM
time2reup's Avatar
goodluck,
Ant
Yes it is the Kicker, actually its yours ny96max
I had to change my user id because my old one got locked up and I couldn't do anything on the forums. So MaximaDave any ideas for the in dash cross over? I had a pioneer Cd-630 off of ebay that was fully flexible and had three boosts. I really only need the bass boost. But I want to put it under my radio so I can adjust when I need to on the fly. Any ideas? Also how much for the W-3s shipped to 22908? Thanks
Old Feb 8, 2002 | 10:50 AM
maximadave's Avatar
JL 12W3's are $159.00 each if you have a Tweeter store near you. I can't ship out any JL product per my dealer agreement with them. I don't carry any indash crossovers....sorry Buy a cd player that has a subwoofer output. Some decks even have a crossover adjustment. Example, the Kenwood Excelon line like the KDCX917, KDCX817, and KDCX717. Although, these models are being discontinued shortly, you can find some deals on some closeouts. Check around at some of your local shops. The new lineup should be here in about a month or so.
