Head Unit Sticking Out
Old Feb 9, 2002 | 08:27 AM
AznStevie's Avatar
I just installed a panasonic deck replacing my bose head unit...but the deck is stick out.... what did you all do to fix this? did you all drill another hole ?? thanx!
Old Feb 9, 2002 | 08:43 AM
MaxDriver98's Avatar
I have the same problem.
Old Feb 9, 2002 | 08:52 AM
AznStevie's Avatar
join the family hahaha....my g/f was like..it looks good from the front..but dang...when look on the side.... it's nasty!!!!
Old Feb 9, 2002 | 10:35 AM
shortchaz's Avatar
The only way I know of is to drill new holes where you want the deck to sit, you also have to grind or drill out the other holes to get rid of the extra bent in metal(maybe a hammer works too?) I haven't done this yet though cause it is still too damn cold.
Old Feb 9, 2002 | 05:08 PM
95emeraldgxe's Avatar
use a hammer - but seriously.......is this only for panasonic head units or have others had this problem as well with other brands?
Old Feb 10, 2002 | 09:39 PM
CanuckAMP's Avatar
If you want it flush mounted you will need to get a custom fabricated bracket made by a car audio shop....
Old Feb 10, 2002 | 09:48 PM
StaindMaxima's Avatar
Radio sticking out?
All radios will stick out. The holes on the sides of aftermarket radios are designed specifically to line up with what is called an "iso-din" application (what is in our cars). Notice if you remove your faceplate (on most radios) the exposed panel actually IS flush with the dash, in most cases.
But, to get the faceplace to sit flush you will need to take the factory brackets and drill holes approximately 1/2" directly to the rear of the holes that you are currently using. Make sure the holes are exactly behind the current ones, not below or above or your radio will be crooked and uneven. Also by moving the radio back, you will be able to use the plastic trim piece that came with the radio, which you would normally discard when installing an iso-din radio.
justmax's Avatar
WRONG!!
I have a brand new Kenwood 817 deck, and it fits FLUSH!!! My Sony active black M600 was stolen a month ago, and it stuck out like 1/2 inch, but this Kenwood fits flush with the back of the trim bezel around the radio.
You have your solution, go execute it.
Old Feb 10, 2002 | 09:50 PM
justmax's Avatar
Re: Radio sticking out?
yep, I was able to use Kenwood's plastic trim too, no cutting or drilling!
Old Feb 10, 2002 | 09:52 PM
Llfe's Avatar
the pioneer sits almost flush
Old Feb 10, 2002 | 10:14 PM
The kenwood solution is only valid on their MASK radios, aka the ones that the face flips over on. They make a special trim piece for iso-dins. The lower model kenwoods will give the same sticking out problem.
Old Feb 10, 2002 | 11:34 PM
justmax's Avatar
Ah, good info... indeed my 817 is a MASK deck.
Old Feb 20, 2002 | 10:56 AM
JeepRage's Avatar
mine is flush too... glad i went with the kenwood eXcelon without knowing
Old Mar 2, 2002 | 08:00 PM
pjalst
Re: Mine sticks out too
Originally posted by slammed95
My sony xplod cdx-m610 sticks out like 1/4 inch. This is only with the black face showing. When I flip it to the other face, the head unit fits perfect. The trim ring that came with the installation kit doesn't fit.
same thing happened to me, i just use it without the trim rim. doesn't look bad
Old Mar 2, 2002 | 11:01 PM
chinaonnitrous1's Avatar
ok ok..i do this at least once a day..for toyota..and nissans and some others..its called a ISO mount...the best way to make it look super sweet is...to remove your stock radio with pocket..in its original brackets.....now remove your stock deck..slip in your aftermarket stereo WITH faceplate, WITH the trim ring...now make a note of where the holes line up and drill..its 4 holes..takes me about 4 minits to get it aligned and drilled...when your done you have a awesome looking deck behind your dash bezel peice...The soloution is in the install..Nothing needs to be fabricated..nothing special is needed..just a drill! Or have a shop Custom-iso mount your deck..bring it to a shop..and ask them to make the face flush with the pocket.! should charge you like 12 bucks
Old Mar 3, 2002 | 05:03 PM
Schmoo
So I suppose this should be common sense, but I'll go ahead and say it:
Drill the bracket, not the deck. You don't want to damage your deck or get bits of metal into it which may short it out.
Old Mar 3, 2002 | 05:20 PM
OOOOOH.....i should mention to use a PENCIL and a ruler to draw lines corresponding to the new holes you need to drill on the bracket...from your new stereo..when you line up the new stereo on top of your existing one still mounted to its brackets.just use a ruler and draw straight down from the holes you wanna use on your deck..then REMOVE your old radio..and drill into the bracket. Sorry about the mix-up
Old Mar 6, 2002 | 09:37 AM
meccanoble's Avatar
Sports Button FTW
yup, that's why i stick with Kenwood
Old Mar 6, 2002 | 01:29 PM
grunge's Avatar
I got the rim to fit
The rim will fit if your good with a dremel.
I got mine to fit on my rockford. the ring makes it look like it belongs there.
worldwiderecognized
Sep 30, 2015 01:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
