5th generation
Old Nov 19, 2000 | 01:04 PM
THEKNITE's Avatar
where exactly is the hole inbetween the engine compartment and the inside to run the power wire through???
thnx
peace
Old Nov 20, 2000 | 07:28 PM
THEKNITE's Avatar
THNX
THNX ANYWAY, I'M SURE NONE OF YOU HAVE SYSTEMS IN.
PEACE
Old Nov 22, 2000 | 03:42 PM
Sly's Avatar
Sly
No one has responded because no one has found a good one. Your best bet is to DIY. Drill a hole at a convenient, unpopulated location on the firewall. Paint the exposed metal edges to prevent rust. Use a grommet to protect your wiring. Finally use RTV on both sides to seal it and keep water out. If you don't like drilling through sheetmetal, carefully drill a hole through one of the existing grommets parallel to the factory wiring, or the throttle cable, or something. Again, use RTV to seal it.
[Edited by Sly on 11-22-2000 at 05:47 PM]
Old Nov 23, 2000 | 03:32 PM
THEKNITE's Avatar
THANK YOU!!!
OH OK, THNX
James92SE
142
Jan 2, 2024 09:23 AM
MAXSE5SPD
Sep 17, 2022 04:00 AM
Mar 12, 2020 12:06 AM
mkaresh
Mar 12, 2018 06:48 PM
rbaksi
Mar 25, 2016 06:10 AM
