is it possible?
Old Apr 20, 2002 | 01:20 PM
GoNe's Avatar
is it possible?
is it possible to run 2 image dynamic, 2 ohm dual voice coils with a bridged rockford amp at 4 ohms?
Old Apr 20, 2002 | 02:13 PM
Coldboot-SE's Avatar
Is it possible
GoNe,
2 possible (working) configurations;
1. running your dual 2 ohm voice coils in series would yeild a 4 ohm load that you could run across a BRIDGED output of your amp
2. running each 2 ohm voice coil to seperate channels (in phase) to
an UNBRIDGED amp would yeild better results
Caution You do not want to run the dual 2 ohm in parallel across a bridged amp output that would put you around a .5 ohm load
Good luck
dave
Old Apr 20, 2002 | 02:20 PM
My Bad
As I see you're trying to bridge across 2 Drivers rather than one, you still come up with 2 ohm load across a bridged amp which is a no go ....sorry for the first reply re-read it after submitting reply
Dave
Old Apr 20, 2002 | 08:40 PM
GoNe's Avatar
dam
Old Apr 21, 2002 | 09:45 AM
jmax
Re: My Bad
Dave
Yeah, the two ohm bridged load that is the equivalent of a stereo one ohm load - from the amps perspective.
Old Apr 21, 2002 | 09:48 AM
jmax
Re: My Bad
Dave
Actually you were right. The one ohm bridged load is the equivalent of a stereo one-half ohm load - from the amps perspective. I don't see any problem with number 1 or number 2. They should have the same net result.
Old Apr 22, 2002 | 03:07 PM
GoNe's Avatar
Re: Re: My Bad
so then it is not going to be possible to hook it up to a fosgate amp that has 360 watts @ 4 ohms
Old Apr 23, 2002 | 10:31 AM
jmax
Re: Re: Re: My Bad
It is possible to hook it up. But the speakers and coils need to be hooked up in series. 2 + 2 + 2 + 2 = 8 ohms. The power will be the same as the stereo 4 ohm power.
