JL Audio 12W0?
Old Nov 28, 2000 | 02:14 PM
Nathan's Avatar
I have a 225watt Rockford Fosgate amp and I'm looking for a subwoofer. I was looking at one JL Audio 12W0 4ohm sub with a peak power of 125watts. Can I use this 125watt sub with my amp or will I blow the sub?
Old Nov 28, 2000 | 02:34 PM
Botos's Avatar
You can use whatever you want with your amp, and as long as the gain is adjusted right, you won't blow it out. The general process for setting up the gain is to connect just one amp at a time, put your head unit on 90% or so of volume, turn up the gain until you hear the first bit of distortion, and then turn it back down a bit.
Old Nov 28, 2000 | 05:24 PM
Synki's Avatar
You will be fine with that amp/sub setup. Just adjust the gain right as Botos said before. The max you should ever set the gain at is 75%, any higher then that, you will have a lot more distortion. The JL subs are very durable, they can handle a lot of power, they are all underrated specs.
Old Nov 28, 2000 | 06:22 PM
Micah95GLE's Avatar
Exactly which amp is it?
Old Nov 28, 2000 | 06:57 PM
Nathan's Avatar
The sub is a RF-2.9x amp which is not sold anymore. I got it for $50 American.
Robert Schneeweis
Jan 11, 2017 06:47 PM
Fbana41
Aug 29, 2016 12:18 PM
Excalibur23
Oct 13, 2015 04:33 PM
BrandonCause
Sep 20, 2015 10:20 PM
popdedop
Sep 11, 2015 11:17 AM
