Tap into Rear Bose for power...
Just trying to cut some corners, I have a 92Se with remnants of the bose system. I want to know If I can tap into the power supply wire of the disconnected bose amp, if so which one is it? This will save a bit of time. It is a small amp just to dive the 2 6x9 coax's in the rear deck. Is there a ground I can tap in to also. I know I am lazy but why reinvent the wheel!
Thanks,
Kevin
Thanks,
Kevin
i dunno about that..but i am using the wire for the complete bose amp in the trunk of my car (1 amp controls 4 speakers) to power up my 6" lcd screen stereo...its brain/tv tuner..cd changer..and its a 40x4peak power stereo..without probs...i dunno if the same applys since each speaker has its own amp..if you tie both hot ( +12v ) wires togetehr you might be able to get away with it...
doctorpullit
Sep 10, 2015 06:33 PM
