Color of 12V power source behind HU?
Old May 12, 2002 | 02:43 PM
Nathan's Avatar
I'm currently trying to wire a Varad scanner and I've so far hooked up the 12V ignition wire behind the stock non bose headunit on my 2k2 max. I now have to wire the scanner to a 12V power source but I'm not sure which wire it is behind my headunit. Can someone tell me which color wire it is and on which harness it is on? Thanks,
Nathan
Old May 13, 2002 | 07:29 AM
studman's Avatar
Why you'd want to power your scanner with the radio's power is beyond me, as I would find a switched and unswitched fuse at the fuse box. But anyway, here is what you are looking for.
2002 Audio System:
Constant Power: Terminal 6 Yellow Wire
Switched Power: Terminal 10 Purple Wire
The Connector is a 10 pin connector that looks like this:
|10|8|XXX|4|2|
|XX|7|6|5|3|1|
Old May 13, 2002 | 02:21 PM
Nathan's Avatar
2002 Audio System:
|10|8|XXX|4|2|
|XX|7|6|5|3|1|
Thanks man, that was a great help.
Nathan
Old May 13, 2002 | 07:32 PM
ny96max's Avatar
you guys should invest in a DMM or LP. They can help you in many situations!
Old May 13, 2002 | 08:39 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Re: Color of 12V power source behind HU?
Nathan
Why not just go to the main ignition harness? Instead of pulling your radio.
Old May 13, 2002 | 08:41 PM
Pearl96Max's Avatar
Yes!!!! I couldnt agree more!
AaronL
Nov 15, 2020 11:52 AM
conansriver
Sep 11, 2015 10:26 AM
Maxima.KsA
Sep 8, 2015 11:33 PM
