4th Gen Owners: Has anyone removed the sheet metal behing the rear seat?
I was wondering if removing the piece of sheet metal would help get more bass in the cabin? Are there any safety concerns with removing it?
The biggest safety concern would be if the subs were not firmly mounted. If you hit the brakes the sub, amps and anything else unsecured will slam into the back of your head, carry it through the windshield, and into the rear window of the person you rear ended.
Other than that it adds a tiny amount of stiffness to the rear end of the car. I've removed mine. Layered it in glass and carbon fiber, damping material and replaced it. It's held in place by several 10mm hex drive, 6mm diameter screws.
so did you get more bass in the cabin area and I assumed you also replaced the seats??
Any panel resonance that is eliminated is more a benefit than a loss. You may loose a fraction of SPL, but you gain considerably more by eliminateing noise that is added to the sound. The noise of the panel vibrating. If you have ever listened to a live band with no amplifiers did you notice the snare drum. Did the snare vibrate against the drum when it was not in use? This is the same type of thing. By eliminateing the unwanted vibrations of body panels you raise the signal to noise ratio of the car.
Re: 4th Gen Owners: Has anyone removed the sheet metal behing the rear seat?
I did remove sheet metal in my Max to mount 2 free air subs in the rear deck though. THAT was a pain... but worth it.
Finkle
Sep 27, 2015 09:53 PM
Huttig2009
Sep 25, 2015 03:31 PM
kirkhilles
Aug 8, 2015 10:53 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
