power windows/locks not working, passenger window open! PLEASE HELP BEFORE IT RAINS
Old Jun 1, 2002 | 03:19 PM
Speebs's Avatar
I aim to misbehave.
OK, here's the deal. I checked all the fuses and they are all fine (the ones under the hood and the ones under the steering wheel).
Last night, I changed the 194 bulb from the courtesy light in the driver door. It worked, then I put the old bulb (which was working before) back in to compare color. The bulb didn't go on, and when I replaced it with the new bulb, that one didn't work either. I took the whole harness over to the passenger door and it worked fine with both bulbs. The harness from the passenger door didn't work in the driver door. So, nothing's wrong with either the harnesses or the bulbs, and I didn't yank any cords or anything (just pushed in the bulbs normally). Then today I noticed that none of the windows will roll down regardless of what switch you use (driver switch OR a specific door), and the driver lock doesn't lock all the whole car like it used to. The passenger lock does still do that, however. Also, when I use the keyless entry it doesn't lock or unlock the driver door. It appears that this lock and window panel is completely disconnected right now in addition to the driver's courtesy step light. HOW DID THIS HAPPEN??? ALL I DID WAS CHANGE A STUPID BULB!!
Does anyone have any ideas? It's summer and I really want to be able to open the windows!!!!!! Please!!
Thanks...
Doug
jerrod99_se-l
Aug 27, 2015 08:27 PM
shaunkey1
Aug 18, 2015 10:09 PM
george__
Aug 18, 2015 07:06 PM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
