People with MTX 1000d
Old Jun 4, 2002 | 09:36 AM
mb1's Avatar
mb1
What is the lowest ohm setting have you run the amp in. I am planing on giving it a 1.5 ohm load for daily use, can it handle that?
Old Jun 4, 2002 | 10:25 AM
jmax
This is more complex than the simple math equations suggest. A pair of 3 ohm woofers wired in parallel yields 1.5 ohms. But only if the speakers really are 3 ohms to begin with. Add to that the fact that the impedance varies with frequency and box design. And then consider that resistance increases as the wires and voice coil heat up. So the more power you send the speaker, the higher the impedance will be. It might work fine, or it might overheat. But with the quality of MTX products you can expect that a fuse will blow or the amp will shut off before the amp burns out.
Old Jun 4, 2002 | 01:13 PM
mb1's Avatar
mb1
Well, MTX hasn't exactly proven their quality to me with this amp. It first blew after I had it for 3 month, and them after 1.5 month later when they sent it back, it was still not working. So I am a little worried about running it outside it's limit. I am going to run 2 audiobahn alum15x's with dual 6ohm coils. They will be in a sealed bod with ~1.25cuf of space.Do you think the amp can handle that?
Old Jun 4, 2002 | 01:23 PM
rawkus2g's Avatar
at what ohm where you running it the first time it blew?
Old Jun 4, 2002 | 07:00 PM
mb1's Avatar
mb1
I think it was at 4ohm.(one sub) It just made a sound, and quit working.
Old Jun 4, 2002 | 07:59 PM
ny96max's Avatar
Re: People with MTX 1000d
YES
Ant
litch
123
Jan 4, 2024 07:01 PM
gavin68
Sep 18, 2021 12:36 PM
mkaresh
Mar 12, 2018 06:48 PM
REDinLV
Sep 28, 2015 12:31 AM
