200 x 2 rms @ 4 ohms??
Old Jun 5, 2002 | 06:14 AM
ZIPPIN's Avatar
Mauja He Mauja
Hi guys. I have been looking for an amp that will put out
200 rms x 2 @ 4 ohms. I have 2 alpine DVC 1241D's, 300 @ 4ohms rms, in a sealed enclosure.
It seems like most of the newer alpine amps are single channel. I saw the audiobhan A4601Q, it puts out 210 x2 bridged rms. What do u guys think of that? Also the Alpine MRV-1507 ( $440 ), puts out 300 rms x 2 @ 4ohms.
can you guys please suggest some good amps please. appreciate it
Old Jun 5, 2002 | 03:18 PM
ZIPPIN's Avatar
Mauja He Mauja
common,,someone must have input
Old Jun 5, 2002 | 04:04 PM
Gates's Avatar
The Type Rs are great subs. I wouldn't run them at 4 ohms, you wouldn't be using the full capabilities of your amp. If you run them at 2 ohms (wire the subs in parallel), you can pickup a JBL 600.1 for around $200. The Type Rs are rated at 300 RMS, but they can take a lot more if you want to give them more power. You'd be safe giving them 400-500 each. Either way, they'll pound. WHat kind of box are you going to be using? I've heard these out of a ported box and they sounded great.
Old Jun 5, 2002 | 05:37 PM
mpc578's Avatar
I have an MTX Thunder 2300 that is rated only at 150 X 2 RMS, however all MTX amps are underrated. Every Amp is bench tested before it is released, and mine was rated at 227 X 2 RMS. My friend also has an MTX rated 30 X 2 in the books, but preformed at 57 X 2 RMS.
Old Jun 5, 2002 | 05:50 PM
KnowledgeBorn's Avatar
Look at the Xtant amps or the JBL 600.1 or even the JL Audio amps, all good clean power, JBL much cheaper though.....
Old Jun 5, 2002 | 07:44 PM
ZIPPIN's Avatar
Mauja He Mauja
i have a sealed box. i thought that i had to run them @ 4ohmssince they are 12" Type-R Series Subwoofer (4ohm + 4ohm. i am sorry but i have never quite understood how that works. won't running them @ 2ohms mess up the subs??
thanks
Old Jun 6, 2002 | 02:44 AM
Gates's Avatar
Yeah, it's a little complicated. I don't really understand it too well either, I usually have to look at a chart before I hook up any subs. But I do know that the dual 4 ohm design will allow you to run two subs at 2 ohms if you wire them in parallel. It definately won't mess up your subs. If you have a manual with your subs, they'll probably show a simple chart about the different ways you can hook it up. You can run the subs at 4 ohms, but you won't be using your amps full capability.
thanks
jmlee44
Oct 2, 2022 02:13 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
bryants95max
Oct 2, 2015 12:52 PM
Socalstillen
Sep 26, 2015 12:01 PM
