Where is the Bose amp and why...
Where is the amp for the factory BOSE system??? and why the hell can't i just run an aftermarket head unit to it like a conventional amp why do i have to send it a signal with no voltage??? so anyway where is it???
Re: Where is the Bose amp and why...
There is an amp on each speaker, 4 amps total. The reason you can just simply replace the Bose HU is because the signal coming out of the HU is not a standard RCA line out type signal. Bose runs to the beat of a different drummer.
DW Originally posted by alexamparo Where is the amp for the factory BOSE system??? and why the hell can't i just run an aftermarket head unit to it like a conventional amp why do i have to send it a signal with no voltage??? so anyway where is it??? |
The magical black bose boxes are located in the front doors right next to the speakers, and in the rear right under the speaker pods I believe. If you want to use an aftermarket deck with all the stock bose speakers, you'll need the bose adaptor, but using the adaptor may come at the price of a slight decrease in overall sound quality.
Could take it as the perfect opportunity to gut out your car and use all different components. I just did my head unit/door speaker install this weekend, and left the stock wiring/amps in place in case I decide to stock everything back out when I sell the max. You might think the stock bose sounds adequate like I did, but even the $100 (eclipse) coaxials I bought made a big difference in sound quality/clarity (and those are coaxials, so a nice component set + some bass in the trunk would be a world of difference). |
Originally posted by blizz20oma The magical black bose boxes are located in the front doors right next to the speakers, and in the rear right under the speaker pods I believe. If you want to use an aftermarket deck with all the stock bose speakers, you'll need the bose adaptor, but using the adaptor may come at the price of a slight decrease in overall sound quality. Could take it as the perfect opportunity to gut out your car and use all different components. I just did my head unit/door speaker install this weekend, and left the stock wiring/amps in place in case I decide to stock everything back out when I sell the max. You might think the stock bose sounds adequate like I did, but even the $100 (eclipse) coaxials I bought made a big difference in sound quality/clarity (and those are coaxials, so a nice component set + some bass in the trunk would be a world of difference). |
It depends on the year of your Max. In the 2002 the amp is in the trunk.
Stereodude |
he has a 97... i was contemplating re-doing my system as i already havea really nice HU in my truck that i can take out ($600 alpine 60wx4) and i work at BestBuy so speakers are cheap...
yo nelson hit me up at school and i will see if i can hook you up with some speakers cheap from work... (if we have anything you like... i persoanlly like the 6.5 and 6x9 cerwin vega HED components i think they sound pretty good) |
© 2024 MH Sub I, LLC dba Internet Brands
