Ohms question on bridging
Old Jun 7, 2002 | 10:08 AM
tomj's Avatar
I am not an electrician so bare with me. I have a 4 channel amp and I want to run one dual voice coil sub off of the 2 rear channels. The amp is 4 ohm so if I connect the 2 rear channels to the sub will it be 2ohms then? Or because it is a dvc sub will it still be 4 ohms? Just curious. Also I was thinking about putting a crossover in between the amp and subs and deck speakers. Does this make sense? Thanks for the help for an audio newbie.
Old Jun 7, 2002 | 10:58 AM
Damion's Avatar
If you are funning the sub off of one channel of the amp then it will be 2 ohms +to+ and-to- but if you are running it off of 2 channels then it will be a 4 ohm load. DVC speakers are usually looked at as two seperate speakers in one. I hope this helps
Old Jun 7, 2002 | 12:33 PM
tomj's Avatar
That's what I was thinking. Now I just have to decide which dvc sub. I'm thinking infinity. Is 65 w rms/ 115 peak per channel too little to power 1 sub? The infinity is rated at 250 rms. 130 enough?
Old Jun 7, 2002 | 01:06 PM
mb1's Avatar
mb1
Why are you getting a DVC sub? I suggest going for a single 4ohm to start with. That way you can bridge your rear channelwithout overloading the amp.
jmlee44
Oct 2, 2022 02:13 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
