FS: ARC AUDIO 2500xxk
Old May 21, 2007 | 05:54 PM
Maroon'dMaxSE's Avatar
Purchased from Don/PearlMax96, I have to sell this amp. This amp is fully and completely functional. Don gave me a 3 year warranty which I believe can be passed on. The only issue is that last time I turned it on, the clipping light would turn on and the amp would shut off. I asked Don about this issue and his reply was:
Originally Posted by Pearl96max
The input stages of the 2500 are Very sensitive a bad/dirty signal will yield those results. "Resetting" a HU will not change the signal it sends out, itll just make you reset your clock and presets.
I had the same problem when I ran them in my AV6, went through two of em before I changed my source.
So its not broke or anything, Its still functioning. Price for the amp is $400.00 which is a COMPLETE STEAL!!
• 2 Channel Amplifier
• 270W x 2 @ 4 ohms Stereo
• 525W x 2 @ 2 ohms Stereo
• 1050W x 1 @ 4 ohms Mono
• Fan Cooled
• 12dB Stereo crossover
• Crossover range: 55Hz-5.5KHz
• 18dB bass boost: @45Hz
• Mosfet power supply
• Protection for Overload
Originally Posted by packetattack
ARC Audio makes absolutely insane amps. Very very high current. For all you guy out there running caps in your car, you don't need it with such an efficient amp. I had a 1500w and a 1000w ARC running in my car with no cap, and no light dimming.
-Ali
(516)870-2644
Old May 23, 2007 | 12:23 PM
nismos14's Avatar
§č~Ū fŪČÄk
What headunit are you running? What is the signal coming into the amp? What are you replacing the amp with?
Old May 23, 2007 | 01:21 PM
Im not replacing the amp with anything...I am selling it..I bought another car
I have a Alpine head unit running with it
Robert Schneeweis
Jan 11, 2017 06:47 PM
Fbana41
Aug 29, 2016 12:18 PM
Excalibur23
Oct 13, 2015 04:33 PM
BrandonCause
Sep 20, 2015 10:20 PM
popdedop
Sep 11, 2015 11:17 AM
