Fs: Jl 500/1
Old Jun 8, 2007 | 10:43 AM
1FSTMAX's Avatar
Fs: Jl 500/1
I have a JL Audio 500/1 Amp. It was only used for like a week. I was using it to run 2 10" crossfire bmf subs. Nothing wrong with it. It's in perfect condition. I paid 300 bucks for it. Willing to let it go for 265 + shipping.
Description: Class D Monoblock Subwoofer Amplifier
Patented Technology: High-Damping Class D Circuit with discrete control circuitry (U.S. Patent #6,441,685)
Differential-Balanced Input Topology: 1 pair of inputs
On-board Crossover: Fully-variable (40-200 Hz), selectable-slope (12 or 24 dB per octave) LP
Preamp Output: 2-channel (independent active filter, parallel with amp filter or pass through)
Bass EQ: Single-band parametric with variable boost up to +15dB and Remote Bass Option
Infrasonic Filter: Fully-variable 24dB/octave from 15-60 Hz
Signal-Sensing Turn-On: Permits operation without remote lead
Dual mono speaker output connections: Accept up to 8 AWG wire
+12V and Ground connections: Accept up to 4 AWG wire
Rated Power: 500 W RMS @ 1.5 ohm - 4 ohm (11V-14.5V)
THD at Rated Power: <0.05% @ 4 ohm
S/N Ratio: >95dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Frequency Response: 5 Hz - 500 Hz (+0, -1dB)
Damping Factor: >500 @ 4 ohm / 50 Hz
>250 @ 2 ohm / 50 Hz
Input Range: Switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions (L x W x H): 13.40 in. x 9.25 in. x 2.36 in.
340 mm x 235 mm x 60 mm
Old Jun 11, 2007 | 02:12 PM
DaBoxSE's Avatar
Hey, is this still available?
Old Jun 11, 2007 | 09:48 PM
1FSTMAX's Avatar
yes sir........ still available..
Old Jun 12, 2007 | 05:18 AM
Cutler's Avatar
Got a 300/2 by chance ?
Old Jun 12, 2007 | 08:29 PM
1FSTMAX's Avatar
sorry this the only JL amp i have..
still up for grabs..
Old Jun 12, 2007 | 11:27 PM
DK_nguyen's Avatar
i have a couple of 300/2 if interested, i'm in fairfax.
Old Jun 20, 2007 | 12:24 PM
1FSTMAX's Avatar
250.00 shipped!!11
Old Jun 21, 2007 | 04:59 PM
2AZN2DMAX's Avatar
Pics to oliversilva@msn.com
Old Jun 22, 2007 | 06:08 PM
1FSTMAX's Avatar
Old Jun 23, 2007 | 01:47 PM
maximillien's Avatar
im from OC how much picked up?
Old Jun 24, 2007 | 07:52 AM
1FSTMAX's Avatar
235 picked up!
Old Jun 25, 2007 | 05:47 PM
1FSTMAX's Avatar
225 shipped!?
Old Jun 25, 2007 | 05:49 PM
2AZN2DMAX's Avatar
PM sent. ^^^^^^^^^^
Old Jun 25, 2007 | 06:28 PM
2AZN2DMAX's Avatar
Payment sent. SOLD
Maxima_Joe
Nov 25, 2015 08:19 AM
ny96max
Oct 18, 2001 12:06 PM
