Pioneer double din FH_P8800
Old Oct 11, 2007 | 09:49 AM
nismos14's Avatar
§è~® f®ÈÄk
Comes with remote, and wiring harness, trim ring as wel.
$250 shipped.
Comes with an intact nissan harness as well.
Old Oct 11, 2007 | 10:27 AM
nismos14's Avatar
§è~® f®ÈÄk
Old Oct 11, 2007 | 10:35 AM
nismos14's Avatar
§è~® f®ÈÄk
Old Oct 11, 2007 | 10:48 AM
nismos14's Avatar
§è~® f®ÈÄk
Old Oct 11, 2007 | 01:21 PM
nismos14's Avatar
§è~® f®ÈÄk
Check out the price Crutchfield is STILL asking for it, as a scratch and dent item:
http://www.crutchfield.com/S-XeVHtVO...=detailed_info
Old Oct 11, 2007 | 06:52 PM
adamsanders's Avatar
Just asking, but why does this unit cost so much? Does it have a built in cd changer? Also, what shape is yours in, I am interested in upgrading my head unit, so the knowing the perks of this head unit would be nice. Thank you!
Old Oct 12, 2007 | 04:20 AM
nismos14's Avatar
§è~® f®ÈÄk
DSP Sound Control: The DSP feature includes the 13-band graphic EQ, position selector and Auto-equalizing function. Since the unit has built-in DSP, it doesn't need, or include, controls for an external DSP processor.
13-Band Graphic EQ: The following bands may be adjusted up to +/- 6dB for each curve: 50Hz, 80 Hz, 125Hz, 200Hz, 315Hz, 500Hz, 800Hz, 1.3kHz, 2kHz, 3.2kHz, 5kHz, 8kHz and 12.5kHz. Two equalizer curves are can be adjusted and stored into memory. Additionally, the EQ can be set to Flat (off).
Position Selector: This feature allows you to select a seating position and adjust the position (from left to right and front to rear) to make it feel like you're in the center of the Soundfield, no matter where you are seated in the car. The positions you may select from are: All, Front, Front right, or Front left.
Auto-Equalizing: This unit comes with a microphone to analyze and adjust the sound contour of your vehicle. Using the microphone, the Auto-equalizer automatically measures your car's interior acoustic characteristics, and then creates the Auto-equalizer curve based on that information. The microphone plugs into the microphone input jack on the bottom of the motorized panel.
^ those are the main things.
No built in cd changer, it does have cd changer controls though.
This one is in good shape, everything functions perfectly. A little dusty maybe? But not difficult to clean.
worldwiderecognized
Sep 30, 2015 01:16 PM
jaydot901
Sep 29, 2015 01:18 PM
Socalstillen
Sep 26, 2015 12:01 PM
BrandonCause
Sep 20, 2015 10:20 PM
