radio on 4th max
Old May 21, 2009 | 06:42 PM
joew's Avatar
radio on 4th max
i followed the wiring instruction from crutchfield. when i use the CD player, the antenna goes up unlike our OEM CD player. crutchfield support agent said that is how it is wired for after market receiver. are you folks experience the same thing. thanks.
Old May 21, 2009 | 06:46 PM
alset2's Avatar
Yep ,aftermarkets tend to send power to the antenna anytime the unit is on...sucks in a car wash I would guess !
Old May 21, 2009 | 07:08 PM
96blackmaxSE's Avatar
boost me.....
wrong. My alpine HU only send up the antenna when I turn on my radio.
Old May 21, 2009 | 07:28 PM
pmohr's Avatar
No more Maximas...
What the OP neglected to mention is exactly what head unit. Different models behave differently.
Old May 21, 2009 | 10:00 PM
tosheto's Avatar
haha. i have a friend that went to a car wash while listening to his radio and now no antenna (i mean it is broken)
Old May 22, 2009 | 06:06 AM
Bassbreaker's Avatar
my panasonic deck only powers on the antenna when the radio kicks in. Did you buy the antenna adaptor when you installed the deck?
Old May 31, 2009 | 01:34 PM
djluski's Avatar
ok i have a radio problem. i pulled out the entire center column with the radio, ac controls, vents/defroster/clock panel, cig lighter, and shifter bezel. everything worked before removal. now when i tried to put it back, the radio will not turn on but the antenna goes up even of the car is off. as well the clock is not receiving power. i tested the voltage to the radio and with the car off it is only getting about 6 volts. with it running about 8 volts. i didn't screw around with the wiring or anything. what coule the problem be? any ideas/suggestions would be greatly appreciated!
Old May 31, 2009 | 03:20 PM
pmohr's Avatar
No more Maximas...
Have you double checked all of the connections? It does sound like something got screwed up back there when you did the work.
Old May 31, 2009 | 08:27 PM
Coolsaber57's Avatar
Why is this in the FS forum?
Old May 31, 2009 | 08:28 PM
pmohr's Avatar
No more Maximas...
Heh, it was in the 4th gen forum, I guess Kevlo (I assume) intended to move it to the actual AVE forum.
Old Jun 1, 2009 | 11:18 AM
djluski's Avatar
yes, all the connections are good. for some reason power to the clock is also out.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Violator
Sep 9, 2015 10:14 AM
Pnjboyzz
Sep 4, 2015 09:04 AM
