F/S: Eclipse Navigation
Hey guys Im selling my other Eclipse Navi that I had in the Lexus...In perfect condition just as my other one was.. Used for about 4 months..Registered with Eclipse which can be transfered..All wires are included: GPS Antenna, front & rear speaker wiring, remote control (did not come with it originally) and Map disc (MDV-08 maps) the map disc is not the original copy, the original got so scratched up from being in the car i made a duplicate..6.5'' screen..Plays DVD while you drive if you wire correctly..If you want I can include all wiring harness's for 04-06 maxima's..I had them left over from the other Eclipse Navi I sold ( see them in the pics) Asking $420 shipped obo...Model is AVN5435..Need it gone! no low ***** please
Mini Bike Engine.
GX200 Honda Clone
ARC Billet aluminum Connecting Rod w/ ARP bolts
Genuine Honda Flat Top Piston
Genuine Honda File to Fit Ring Set
1.2 Ratio Rocker Arms
26lb Valve Springs
Stainless Intake & Exhaust Valves
Stainless Retainers & Keepers
Chromally Push Rods
ARC Billet Aluminum Intake Manifold w/ pulse fitting
26mm Mikuni Slide Carb
Uni Hi Flow Performance Air Filter
AGK Header w/ D-Port Flange
ARC Light Weight Aluminum Flywheel (3.4lbs compared to 9lbs stock)
Spark Plug indexing kit
Complete head stud & engine bolt kit (Grade 10.9) reduces distortion under high RPM.
Ported & Polish Aluminum Head that has been milled .065 to increase compression to 12.5:1
In addition to the modifications indicated above the follow mods have also been performed.
The govenor has been removed to allow for the full potential of the engine. This engine has been built to be very safe & reliable at increased engine rpm's.
The low oil sensor has been removed to keep the engine from shutting down under high speed acceleration & turning.
The block has been clearenced to allow for the future upgrading of the camshaft. Also the factory compression release is still being utilized to keep this animal easy to pull start.
This engine has never been ran, it is brand new & is looking for a chassis.
I don't know if your into mini bikes, but if you are then you know the capabilities of the engine. I figure this one is realistically going to produce around 14hp. There is over $650 in parts & thats not including the cost of the engine & the custom head work....
If your interest let me know. I would love to make things right with you & I would be willing to lose money on this engine to benefit you after you were so willing to work with me on the Eclipse unit.
GX200 Honda Clone
26lb Valve Springs
Chromally Push Rods
worldwiderecognized
Sep 30, 2015 01:16 PM
