FS: Apexi safc 2
Old Nov 8, 2009 | 08:45 PM
maxima1239's Avatar
FS: Apexi safc 2
140 shipped OBO, very negotiable
item location in florida
Modifies air-flow meter signal (pressure signal in some vehicles) to optimize fuel-air ratio; Vacuum Fluorescent Display (VFD).
The second-generation SAFC is a fuel computer that adjusts fuel/air ratio by modifying the air-flow meter/MAP sensor signal. The SAFC features a user-definable, eight-point, adjustable fuel curve that can be set in 500 RPM increments. The range of fuel adjustment is +/- 50% at each of the user-defined setting points. On hot-wire vehicles, the Deceleration Air Flow Correction function is capable of curing the erratic idle and stall problems associated with open-atmosphere blow-off valves on hot-wire air-flow meter systems. The SAFC is capable of monitoring and replaying the following data channels in Numerical, Analog Meter and Graph displays: Intake Manifold Vacuum/Boost Pressure, Air Flow Capacity, Intake Manifold Pressure, Karmann Frequency, Engine RPM, Throttle Position, and Air Flow Correction %.
Old Nov 10, 2009 | 03:02 PM
maxima1239's Avatar
Taking all offers
Old Nov 12, 2009 | 12:50 PM
nzelinsky's Avatar
$120 Shipped to me in canada? t2y3x7 is the postal code. Check the shipping cost before you decide because its more than lower 48
Old Nov 15, 2009 | 08:01 PM
maxima1239's Avatar
SOLD, thanks for everyones interest
aw11power
Oct 10, 2021 04:57 AM
Maxima_Joe
Nov 25, 2015 08:19 AM
Slamrod
Sep 3, 2015 07:38 PM
t6378tp
Aug 24, 2015 07:03 AM
