FL Grounding kits (New Lower Price)
Old Oct 23, 2010 | 09:13 PM
Shinjiduo's Avatar
Maxima Grounding Kit Spec
I am now selling all of my kits at the reduced price of $54.85 (custom set ups for $57.85) shipped within the U.S. This price drop is down from the previous $63.00 shipped. If ordering from Canada or Mexico it will be $6.50 extra. You can order using the links below:
United States Order Form
Canada and Mexico Order Form
Application Options
4th Gen Kit: $54.85
5th Gen / 5.5 Gen Auto Kit: $54.85
5.5 Gen 6-Speed Kit: $54.85
Custom set up: $57.85
The 5th Gen kit comes with:
1 Throttle body to firewall ground
1 Battery to chassis Ground
1 Engine Block to Chassis Ground
1 Starter to chassis Ground
1 Timing Chain Cover to Chassis Ground
The 5.5 Gen kit come with:
1 Upper Intake Manifold to Firewall Ground
1 Battery to Chassis Ground
1 Stater to Chassis Ground
4th Gen Kit comes with:
1 Air Intake to Firewall Ground
1 Starter to Chassis Ground
All wires are made with Stinger Electronics HPM Hypertwist 4 AWG (1666 strand count). The terminal ends are heavy nickel plated copper and are wrapped in polyolefin shrink wrap.
Color Options:
Translucent Black
Crimson Red
Carbon Grey
Clear Silver
Island Blue
As for the benefits of the kit. For auto transmissions you will notice that the car is no longer resistant to downshifting. This means that the car is more responsive when punch on the gas as the transmission will respond quicker. Also when you slow down to a slow roll the car will downshift appropriately instead of staying in high gear and quickly shifting down. The shifts are also smoother and in general more "precise" feeling. Idle and high speed rev are smoother and I noticed that the power-band actually smoothed out a bit as well whereas before the kit it would seem the car was gasping post 5000 rpm it pulls a bit harder at rpm now (not a earth shattering difference but a mildly noticeable one). The car starts a little faster and stronger. The auxiliary electrical equipment like power windows, power seats move faster and lights all around are a bit brighter especially the headlights. Some people say it helps with mileage and many manufacturers of the kit say it ups horsepower . But basically what it does is reduce power spikes so that your cars various computers can operate more efficiently hence, allowing your vehicle to operate more like new is some ways and even better than new in others. The stock grounding system was designed to be cost cutting, light weight (for gas mileage) and to deteriorate over the years in order to "convince" people they "need" new cars this kit just curbs that normal curve of deterioration.
Old Jan 16, 2011 | 12:32 PM
Shinjiduo's Avatar
Bump
Matt93SE
May 24, 2019 02:58 PM
homeyclaus
Sep 3, 2015 06:15 PM
95Maxi
35
Sep 2, 2015 10:37 AM
