NJ FS: Pair of Eclipse 87121.8's
Old Jun 1, 2011 | 11:20 AM
nismos14's Avatar
§è~® f®ÈÄk
1. Product:
Eclipse 12's, single 8 ohm
2. Specs:
Features
•1˝ santoprene surround
•One-piece Mica-Filled Polypropylene (MFP) cone
•CONEX® dual spider with woven-in tinsel leadwires
•Kapton voice coil former
•4-layer long-throw voice coil
•“Bottomless” design
•Vented pole piece
•Cast aluminum frame
•Double-stacked magnet
•Small sealed-box enclosure
CONEX®: Registered trademark of Teijin Ltd.
material.
ECLIPSE 87001 series subwoofers employ Mica-
Filled Polypropylene (MFP) cone material for
superior rigidity with low mass. The stiffness of
MFP enables ECLIPSE woofers to maintain
excellent distortion characteristics under intense
power applications. The low mass of MFP
ensures bass reproduction that quickly reacts to
the input signal for “count the cycles” accuracy.
MFP’s lightness also increases driver efficiency,
providing more output per given watt of amplifier
power.
1-inch wide santoprene surround.
One-inch wide, 1/2-inch tall surrounds provide a
long, controlled stroke. Santoprene synthetic
rubber is weatherproof, very pliable and durable
at all temperatures and has excellent damping
characteristics to reduce cone resonance
distortions.
• Kapton voice coil former
Handles a significant quantity of heat without
deforming.
• Long-throw bottomless motor structure
Prevents the speaker from “bottoming out”
even during high-power dynamic peaks.
• CONEX® dual spider with woven-in tinsel
leadwires
• 2-inch (2.5-inch 87151.4, 87151.8) voice
coils
• Small sealed-box designs
• Cast aluminum frame
• Double-stacked magnet
87121.8
27Hz
0.43
7.2Ω
1.95 Cuft
0.73˝
300W
600W
Fs 27hz
Qts 0.43
DCR 7.2Ω
Vas 1.95 Cuft
Xmax (one way) 0.73˝
Continuous Power Handling 300rms
Music Power Handling 600 peak
3. Description/Condition:
Used, in great shape, very versatile subs sound amazing and get very very low.
4. Price: :
$225 with grills
5. Pictures:
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
soybeanz
Sep 25, 2015 10:46 AM
lux97Max
Sep 3, 2015 04:51 PM
