TX Pathfinder 6 disc MP3 Headunit for 4th gen w/ Bose - including flush mount brackets
Old Nov 17, 2012 | 03:56 PM
bigd480's Avatar
This the newer generation (no tape deck) Pathfinder 6-disc in-dash changer w/ MP3 support. I had it installed in my 97 GLE but should fit any 4th Gen.
It's as plug and play as it gets for a Maxima w/ Bose - if you can remove your existing radio and tap-splice two wires you're done.
I'm including the mounting brackets as they are drilled for a flush fit. It's just the 2 metal brackets - the pics w/ the trim are to show how flush it is.
Everything works, you don't need any extra wire harnesses or antenna adapters. Condition is very good - there are couple of slight nicks on the plastic at the right and bottom edges but they're not really visible when mounted.
$180 shipped - $160 local pickup in Austin/Houston.
The tap-splice - ACC to amp turn-on lead
Old Nov 17, 2012 | 06:09 PM
95naSTA's Avatar
pm'd
Old Nov 17, 2012 | 06:46 PM
bigd480's Avatar
Replied
Old Nov 18, 2012 | 08:58 AM
bigd480's Avatar
sold
halfpol
Oct 17, 2022 12:16 PM
vingodine
45
May 21, 2016 12:46 PM
schmellyfart
Sep 25, 2015 04:47 PM
lux97Max
Sep 14, 2015 03:54 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
