Autocrossing and Road Course Racing Enjoy and discuss the fun through the twisties at your favorite auto-x event. Check out the links to the SCCA website to locate your local club.
GREAT handling/suspension resource
Old Feb 1, 2006 | 03:55 PM
irish44j's Avatar
retired moderator
I know it's for Sentras, but the chart in the middle is a nice resource to have
http://www.sentra.net/tech/garage/su...03b4e55cb53e0b
Old Feb 1, 2006 | 05:24 PM
97SEdriver's Avatar
this place is dead
I can lift the inside wheel without ANY adjustment
Originally Posted by sentra.net
Big time oversteer, Can cause the inside rear tie to lift off the ground which is not two bad on a FWD car. On Classics, if this happens while trail braking into a turn, the abs can shut the brakes down which can be a bit scary
Thankfully I don't have ABS
FTW
Poor braking, car is road crown sensitive, twitchy, tires wear out on the outside edge You almost never want to have positive camber unless you are a dweeb
Old Feb 1, 2006 | 05:29 PM
RA030726's Avatar
I'm nutty for Nissans
oh yea mike kojima is the man. since i bought an ser i havent even cared about whats available for the maxima. i have been getting tips and tricks off the sr20forum. they really know their stuff. ex. high spring rates, shorter and adjustable dampers, and a small drop.
Old Feb 1, 2006 | 08:22 PM
BEJAY1's Avatar
Conecarver
How is that different than what's available here?
Old Feb 2, 2006 | 04:46 AM
RA030726's Avatar
shortened konis, shigspeed, truechoice, ect. i could go on with all their custom parts. my point is they have a much bigger aftermarket support especially for autox, rr, scca parts.
Old Feb 2, 2006 | 07:13 AM
Norm Peterson's Avatar
JSutter - there may very well be better aftermarket support for the SER, but that's really just end results. Hopefully, most of this wider support has been properly thought out, as you're better of dealing with only one or two sources who have really done their homework (and understand it well enough to be able to accurately explain it) than sifting through similar products from a dozen suppliers that have a total of one clue split up among the whole 12.
Anyway, the general theory/engineering/math is still the same. Only the details differ.
As for the link itself - in the chart at the bottom, keep in mind that the column labelled "Range of adjustment that is useable for most cars" is not intended to be a list of upper-limit values. Specific applications may need/want more of one or more adjustments (though you should have a really good understanding as to why in such cases).
Norm
Old Feb 3, 2006 | 05:10 AM
97SEdriver's Avatar
this place is dead
Well, for rr, I don't know, I've seen at least one SE-R banging off the rev limiter at only like 105-110mph.
Of course it was passing me (turn 1 at Pocono) with some decent mods, but I still was faster in the straights (bone stock).
spencerwh1
Jun 30, 2016 05:44 AM
rbaksi
Mar 25, 2016 06:10 AM
JonBlz
Oct 5, 2015 06:02 PM
Pixel
Sep 15, 2015 05:53 AM
