Aug 12th Philly SCCA Autocross....pic and vids
Gabe (gdmaxse) and me rolled up to the 200-car Philly SCCA event this weekend to represent the land-boats. Perfect weather, nice day to drive and watch. We bumped out of DSP this week to avoid the diabolical teal civic that dominates that class every event, and went to EP (my soon-to-be "real" class) where a VW Scirocco has dominated, winning 6 out of 7 events.
Gee, always fun to be sandwiched in between a Z06 Vette on slicks and a Lotus Elise. Makes me look even slower.
Our run group....as you can see, it was a pretty fast field that included 2 Z06's, 3 Lotus Elises, a 350z, 2 S2000's, 3 Evos, a handfull of STIs/WRXs, and 2 supposed national contenders (a 2.5RS and an STi).
The king of the hill in E-Prepared...gutted interior, full cage, etc etc
The challengers in E-Prepared
The course: it was a good course for the big cars. Not tight at all, very fast and flowing. Overall it was a pretty easy course, and a bit short for a lot as big as this one. I thought it was fun, but heard several Miata and Mini drivers complaining that it "sucked" (like I said, it gave the high-power cars a decided advantage over the low-power roadsters). In any case....we hung in there, and were both in the chase, though never closer than 1.2 seconds from the leader after any of the runs (the leader kept getting faster)
The results: Times aren't posted yet, but if memory serves me the Scirocco (which won the class again) put up a FTD of 37.8. My FTD on my 4th run was 39.2 I believe (good for 2nd), and Gabe was in the high 39's.
the Scirocco driver commented to us that it was "nice to finally have some competition, since the Scirocco had been 5+ seconds ahead of the rest of the EP field at previous events." Gabe supposed that with R-comps he could probably come close to the Scirocco and it's probably true. Then again, the Scirocco apparently has alot of work yet to be done on it as the season progresses. Doh!
Here's a couple of vids of my runs from in/on car. No music this time, tried to capture the sounds of the course/car/etc. Need a better external mic still!
Click here to see Video
More pics are located at:
http://s78.photobucket.com/albums/j8...ss%20Aug%2012/
Originally Posted by Cutler
Nice day guys, good stuff. The miata will be out there next year once the transplant is completed
Irish, how much did it cost you for the day?
I would like to start going to events, but I wanna know how much money I am going to be spending, and also I think I will only really be able to drive tight courses so I can keep the auto in 1st. 1st goes up to around 42mph. How fast were you going in this course as this seemed like a pretty fast course.
the only cars that really ever run courses in 1st are Honda S2000s (9k rpm redline) and a few heavily-modded or FI cars otherwise. Running courses in 1st, even small courses, you will always lose time because it makes it alot harder to modulate throttle at those high rpms, especially in a maxima. You can see I redlined 1st at the first corner. The course I probably didn't get over 50mph or so, but I've been on faster courses. Even the small tight courses I much prefer 2nd to 1st gear. You'll have traction problems in 1st coming out of 40mph turns trying to punch it and then hitting the limiter. In the vid you can see I'm running mid-range rpms (4500 or so) for most of the course, and the maxima has PLENTY of power at that range to pull out of most corners, even slower turns.
At the previous event, a fairly tight course (with top speeds around 40mph) I did one of my 6 runs completely in 1st and it was a full 2 seconds slower than the other 5 runs.
the official results are up
http://www.phillyscca.com/solo2/resu...6/SO081206.TXT
vw scirroco 38.086
josh 39.345
gabe 39.986
and my pisc are
http://filebox.vt.edu/users/gdunn/AutoCross/08-12-06/
vw scirroco 38.086
josh 39.345
gabe 39.986
and my pisc are
arent r comps usually good for at least 3 seconds
. . . and also I think I will only really be able to drive tight courses so I can keep the auto in 1st. 1st goes up to around 42mph. How fast were you going in this course as this seemed like a pretty fast course.
Much of the time, you'll be cornering hard enough that you won't be able to use 100% throttle in 2nd either - out of 40 seconds last Saturday I'd guess that a total of no more than fifteen seconds of that could be called close enough to straight for WOT in either gear. Split that up over several different places; three or four seconds here, a couple more over there, etc., and even an eighth-mile dragstrip starts looking like an eternity to be at WOT.
Norm
vw scirroco 38.086
josh 39.345
gabe 39.986
and my pisc are
vw scirroco 38.086
josh 39.345
gabe 39.986
and my pisc are
1. 132/GS JIM PINCKNEY 05 MINI COOPER S > 35.690 <
TIMES: 1) 36.461 2) 35.690 3) 36.082 4) 36.296
2. 41/GS ERICK GEDGE 05 MINI COOPER S > 36.174 <
TIMES: 1) 39.818( 1) 2) 37.000 3) 36.951 4) 36.174
3. 11/GS STEVEN ROSENBERG 05 MINI COOPER S > 36.314 <
TIMES: 1) 36.596 2) 36.314 3) 36.345 4) 36.694
4. 8/GS CY LEE > 36.324 <
TIMES: 1) 36.915 2) 36.324 3) 36.536 4) 40.611( 1)
5. 111/GS ROBIN LUMB 05 MINI COOPER S > 36.594 <
TIMES: 1) 37.971 2) 36.989 3) 39.019( 1) 4) 36.594
6. 28/GS LARRY STRAHORN 05 MINI COOPER S > 36.635 <
TIMES: 1) 38.027 2) 37.494 3) 36.635 4) 36.966
7. 98/GS YASUHIRO HANE, PHILA 04 MINI COOPER S > 37.066 <
TIMES: 1) 37.328 2) 37.066 3) 38.312 4) 37.516
8. 82/GS FRANK STRAHORN 05 MINI COOPER S > 37.657 <
TIMES: 1) 39.110 2) 39.826 3) 38.185 4) 37.657
9. 69/GS ANDREW BAKER 97 TOYO CELICA ST > 38.263 <
TIMES: 1) 44.965( 3) 2) 41.566( 2) 3) 38.263 4) 41.830( 2)
10. 74/GS STEVE PUFFPAFF 04 ACUR TL > 38.650 <
TIMES: 1) 37.339 O/C 2) 39.945 3) 39.879 4) 38.650
11. 4/GS CHUCK GEDGE, PHILA 05 MINI COOPER S > 39.487 <
TIMES: 1) 43.005 O/C 2) 42.804 3) 40.523 4) 39.487
12. 320/GS JENNIFER SHAFFER 00 PONT PONTIAC > 45.527 <
TIMES: 1) 76.255 2) 52.533 O/C 3) 48.366 4) 45.527
Originally Posted by 97SEdriver
next time you should go to maxima stock class GS
it will SO help your index times.......I'm still surprised it just wasn't ALL
Mini's...Josh I just realized you actually beat one of them...good job
Hey I got a PhillySCCA Pint Glass for 2nd place. Who gives a damn about index? not me.....
Or is that on Cardomain already?
yep, that's the one.....she seems pretty hardcore autocrosser. She was telling us that her husband won't let her get another set of wheels until she sells some of the 12 SETS of wheels/tires in her basement...Apparently she built that car from a rolling junkyard chassis and also has a non-track Scirocco as a daily driver
Also said she has been doing some hillclimb competitions in the Scirocco too
That voice over the PA, haven't heard it in a while, unfortuneatley you didn't catch any of his usual sarcastic comments.
"Gabe Dunn in the Nissan Maxima. I'll tell you, my mom has never driven HER maxima that fast!"
also he ragged repeatedly on teh VW GTI running in STOCK class with a carbon-fiber hood
He had some sarcastic ones for Gabe:
Originally Posted by EnsignB
Darn, they gave a prize for 2nd place? I got 2nd in STS2 and didn't think I'd get anything. Oh well, it still was a blast.
Gabe, I'm taking this weekend off but will be at the next event up there, whenver it is (need to check SCCA/AI schedules).
AaronL
Aug 8, 2020 10:31 AM
NissLover
Aug 22, 2015 10:26 AM
