Harness Question
G-Force 3" 5-point (though I don't use the submarine strap, so it's really a 4-point). I bought the version with extended shoulder straps and they clip into eye bolts mounted using the rear seatbelt bolt holes (have to take back seat bottom out).
I use a corbeau 4 point. its basically a copy of the schroth. It has a clip in the middle so I can disconnect the shoulder straps from the rear mounts to use the back seat. I prefer the 2" wide belts over the 3" for autocross use.
Originally Posted by michaelnyden
using a simpson camlock 5 point...but I also don't use the anti-submarine...currently trying to have a harness bar made...
Originally Posted by Sirl
FYI, the straps that go over your shoulder should not be more than a 40 degree angle downward. It's said to be dangerous if thats the case.
Unfortunately, without a rollbar or harness bar, there's not much you can do about the angle on the maxima.
i'd say mine is at about a 40-degree angle or so anyhow....
True. My dd is my mamixa. I only do track days with my spec. Autox go to boring.
Originally Posted by CustomaX
forget it man i will solve it by my self
Do any of you harness guys have a roll bar? I was talking to some people that said that harnesses without a roll bar/cage are a horrible, dangerous idea because if you roll over you cant duck. I suppose so, but it just isnt very convincing...
yeah a harness without a roll bar is very dangerous if you were to roll over... thats why you shouldnt use the harness on the street or road course without a roll bar. but it is ok to use a harness without a roll bar at autox because the speeds arent really high enough to roll a heavy car like the maxima
So you use the stock belts on the street and throw the harness on at an autox?
Even if they were safe to use on the street, I still wouldn't want to use mine.
Im looking to get a racing harness put in so I can stop sliding all over the damn seats when cornering. It is now getting to the point where it's slowing me down on the corners. The problem is so bad my steering height adjustment comes loose on corners.
I only road course this car and need a good setup in the future to pass tech for certain racing clubs, so there maybe a harness bar in my plans. But for now im looking to get a 3 or 4 point harness. Problem on the 4th gen there is only one seatbelt bolt hole on the rear bench that's OK for a harness bolt in point.
Now are you guys bolting the two rear straps of a 4 point to this one point or are you using some other method? I saw a setup on a 4th gen where it was a 4 point harness but the rear two straps plugged into a single strap. Then this single strap was bolted to the rear seatbelt mounting point. I did not get the name of the maker of the harness so im at a loss as to where to buy it.
Im in need of something quick because the next track event is on the 19th. Over the winter im going to get quotes from race shops and see how bad it would be for a real setup.
why don't you just get a CG-lock until you feel you need more or get a real harness bar? cheaper solution for now until you figure out what you want to do...I have one and it works great since I never got that harness bar made and took out my cam lock 5 point
http://www.cg-lock.com
-Michael
-Michael
CG's a great device but think grassroots cheapo too. Baby seats come with these cool little locking clips that do the same thing. I got a couple from Burlington Coat factory for $3 ea.
So where can I get a harness bar ? I'm interested in one for my Maxima. I have a 4 point Sparco harness in the car right now that I use when doing HPDEs. I don't autoX and I have a set of Corbeau Legacy seats in the car also..... seats help ALOT but the harness keeps you planted. I need a submarine strap, by the end of each session I have my harness up at my chest almost. Its times like this I wish I had a big belly that I could tuck the harness under
there isn't one for our cars, you will have to have a custom one made...there is a guy I have close to me that will do it, but I've been really busy as well as he has otherwise I would have one already.
I can vouch for those CG locks working pretty well. I bought them back in October and used them at two HPDEs. On the 19th I went back to NHIS with the CGs and they made a definite improvement. Also went for the first time to Limerock on the 2nd of November. It's still not the same as a full harness but for the price and ease of installtion you can't go wrong.
Now I need to ditch the stock '98 SE springs/struts that I've been using this season for something stiffer. At NHIS it works OK with the lines that I drive, but the body roll at the higher speeds experienced at Limerock convinced me otherwise.
CAN-Toronto FS: Emanage Ultimate and plug/play Harness
knight_yyz
Nov 6, 2015 02:34 PM
