Autocrossing and Road Course Racing Enjoy and discuss the fun through the twisties at your favorite auto-x event. Check out the links to the SCCA website to locate your local club.
Dry Boiling Point arranged list of high performance brake fluid
Old May 19, 2007 | 09:15 PM
Nealoc187's Avatar
SLOW
I found this list on another forum, thought I'd post it here for those who need their brakes to work at the end of the front straight
NOTE: PRICES BELOW ARE FROM 2005 LIST
ARRANGED BY DRY BOILING POINT:
DRY:401F -- WET:284F --- DOT3 MINIMUM (GLYCOL BASE)
DRY:446F -- WET:311F --- DOT4 MINIMUM (GLYCOL BASE)
DRY:500F -- WET:356F --- DOT5 MINIMUM (SILICONE BASE)
DRY:500F -- WET:356F --- DOT5.1 MINIMUM (GLYCOL BASE)
DRY:500F -- WET:???F --- FORD HEAVY DUTY DOT 3 PM-1C (new since 2006)
DRY:527F -- WET:302F --- AP RACING 551 ($12.95/0.5L OR 16.9 OZ)
DRY:527F -- WET:347F --- VALVOLINE SYNPOWER DOT3 & DOT4
DRY:536F -- WET:388F --- ATE SUPERBLUE/TYP200 ($9.95/1L)
DRY:550F -- WET:284F --- FORD HEAVY DUTY DOT 3 PM-1 (pre 2006) ($4/12 OZ)
DRY:570F -- WET:284F --- WILWOOD 570 ($5.65/12 OZ)
DRY:570F -- WET:284F --- PERFORMANCE Friction Z rated ($6.27/16 OZ)
DRY:572F -- WET:410F --- AP RACING 600 ($16.95/0.5L OR 16.9 OZ)
DRY:590F -- WET:518F --- CASTROL SRF ($69.00/1L 0R 33.8 OZ)
DRY:593F -- WET:421F --- MOTUL RBF600 ($12.95/0.5L OR 16.9 OZ)
DRY:601F -- WET:399F --- BREMBO LCF 600 PLUS ($26.75/0.5L OR 16.9 OZ)
DRY:608F -- WET:390F --- AP RACING 660 ($28.99/0.5L OR 16.9 OZ)
DRY:610F -- WET:421F --- NEO SYNTHETICS SUPER DOT 610 ($11.95/12 OZ)
DRY:626F -- WET:417F --- QUADRIGA/PROSPEED GS610 ($14.99/16 OZ)
DRY:626F -- WET:417F --- WILWOOD EXP 600 ($16.95/0.5L 16.9 OZ)
DRY:635F -- WET:430F --- PROJECT MU G/FOUR 335 ($45.00/1.0L 33.8 OZ)
Old May 20, 2007 | 07:42 PM
Matt93SE's Avatar
STFU n00b!
I've got a post around here somewhere that has about 25 brands of wet/dry boiling points and prices and such.
Edit... okay, so it was 15 different fluids.
http://forums.maxima.org/showthread.php?t=402732
not the same high $$$ stuff as that, but 99.99% of the people on this forum will never need anything on the list above.
Old May 20, 2007 | 09:26 PM
Nealoc187's Avatar
SLOW
Yeah some of the stuff on that list is pretty wildly priced. I've still got a couple bottles of unopened pre-2006 550* Ford HD on the shelf in the garage.
Old May 23, 2007 | 09:14 AM
DandyMax's Avatar
3.5 in the works
Good stuff guys. Thanks for the lists.
Old May 23, 2007 | 06:51 PM
BEJAY1's Avatar
Conecarver
Based on suggestions like these I switched from Motul 600 costing $100/gal to Valvoline at 1/4 the price. It's dry boiling point is right at my temp limit and it's a bargain to replace each year.
Old May 25, 2007 | 01:51 PM
Matt93SE's Avatar
STFU n00b!
I've been using ATE Blue/yellow and am switching to the valvoline pretty much. even with slicks and 100* weather here, I still haven't boiled the fluid in either car yet.. why pay for something I don't need?
Old May 27, 2007 | 07:53 AM
SR20DEN's Avatar
VQ Wizard
I am glad I am not the only one thinking this way and considering that exact same switch.
Old May 27, 2007 | 11:42 AM
gaan919's Avatar
SRF would be good if you want to just leave it in there for a year. Otherwise, I've been running Valvoline and it's been fine. You can find them anywhere and they cost about $6 for a big bottle.
homeyclaus
Sep 3, 2015 06:15 PM
homewrecker
Aug 24, 2015 08:56 PM
FlaMark
Aug 20, 2015 12:17 PM
Abdelrhman
Aug 17, 2015 12:16 PM
egali045
Aug 16, 2015 01:19 PM
