Autocrossing and Road Course Racing Enjoy and discuss the fun through the twisties at your favorite auto-x event. Check out the links to the SCCA website to locate your local club.
post your KYB-AGX autoX settings
Old Jun 17, 2002 | 08:25 AM
theblue's Avatar
I run with 4 on the front and 5 on the back (to get that little extra oversteer).
Old Jun 17, 2002 | 12:03 PM
iwannabmw's Avatar
Re: post your KYB-AGX autoX settings
4/8 with 1-2 psi less in the rear tires works great for me to help get the car to rotate.
Old Jun 19, 2002 | 09:38 PM
NotNew!!NewSN!!'s Avatar
when i finally get to the track cuz i been bizy, im gonna be using 3 on the front and probably 7 on the rear, always want the rear to be stiffer then the front on autocross
Old Jun 19, 2002 | 11:46 PM
Maximus1000's Avatar
First time I tried it....3 in front and 8 in rear. Talk about tail wagging. It was alot of fun (especially for the camera), but hurt my times alot. My best runs have been at a setting of 3 in the front and 5 in the rear. I'm gonna experiment more at the next event now that I have a rear sway bar as well.
Old Jun 25, 2002 | 05:06 AM
Lime's Avatar
2/4 (factory) settings at the moment...was considering 3/5 for this Sunday's event.
Old Jul 14, 2002 | 06:32 PM
Blade_99SE's Avatar
I've had a lot of success with the fronts set to 2 and rear set to 8. This give me a more secure feeling all the way around. The front doesn't rebound too quickly and the rear is stiff enough to rotate when you need it to. If you have you front to stiff the car will rotate to easily. You have to find a happy combo for your liking and cars set up.
Old Aug 25, 2002 | 04:22 PM
nismo2020's Avatar
Needs non-Maxima Friends
i started out with 3/6. then i was getting a lot of plow from the front tires so i went to the hardest setting which i still got plow. i need to play with tire pressure.
Old Sep 12, 2002 | 01:31 PM
deezo's Avatar
You may need to stiffen up on the rear a bit to counter the plow but tire pressure is a good place to start.
Old Sep 28, 2002 | 11:33 PM
KWheelzSB's Avatar
3 - F
5 - R
-Worked well for me on Thunderhill's roadcourse. Not actually Auto-X, so I'm sorry if it's considered O/T; just trying to add to the data.
For Auto-X I'd probably experiment with either 3 or 4 on the front & bump the rear up to 6 or 7. (Totally speculating at this point, based on my handling impressions at the racetrack).
Old Sep 30, 2002 | 10:38 AM
breaux124's Avatar
First run I did 2 front and 7 rear, and my car seemed to roll and plow a little to much. I then stiffened the front to 3 and kept the rear at 7 and it felt much better.
Then again, it's a combination of many things - Tire's, tire pressure, wheels, springs, etc. So try a few different combinations and see what YOU feel more comfortable with.
FYI: For a few days I kept it set at 3/7 and the car didn't feel too bad. For fun I changed to 1/3 and WOW, it's much softer but feels very "floaty" and unstable. After driving around with 3/7, the soft setting of 1/2 makes me almost scared to take turns remotely fast. I changed back to 2/4 for everyday driving.
pktaske
May 6, 2016 07:49 AM
Hdnseek
Sep 9, 2015 05:55 AM
03VQMAX
Sep 5, 2015 03:47 PM
pktaske
Sep 4, 2015 08:40 AM
