Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
which product to remove swirl marks?
Old Jun 10, 2003 | 09:46 PM
nadir_s's Avatar
vicodin ... gift of life
I read that they have specific producs that would remove swirl marks... and w/ superblack paint, my paint is full of micro scratches and such.. along w/ the swirl marks.
What products have you guys come across that works best against swirls? Also, is it something I could find locally?
Old Jun 11, 2003 | 12:24 AM
Dave Holmes's Avatar
I use Meguiars #9 Swirl Remover. You can use it by hand or machine. And it isn't too aggressive that it'll damage the paint. My car is arctic pearl white, and it gives it a mirror, but "wet" finish, ready for waxing. I can only imagine the depth it will give you on your superblack!
Dave
Old Jun 11, 2003 | 09:24 AM
PrinzII's Avatar
OG and counting...
Since Meguiar's was mentioned, you might want to consider Meguiar's Dual Action Cleaner Polish. This product is effective in getting swirls out.
I am also going to be experimenting with 3M's Perfect-It III.
I already have 3M Swirl Remover for Dark Colored Cars and Meguiar's #9 Swirl Mark Remover.
Old Jun 11, 2003 | 02:29 PM
DanNY's Avatar
Ad·min·is·tra·tor
for me...
3M swirl remover for dark car or 3M dark car glaze on a foam pad.
Old Jun 11, 2003 | 07:28 PM
95emeraldgxe's Avatar
Originally posted by DanNY
for me...
alot of people seem to praise 3M, i tried their wax once and i hated it, i guess they are stronger in some areas over others
Old Jun 11, 2003 | 07:29 PM
nadir_s's Avatar
where do you guys get your stuff from? Any major stores carry em? (ie. walmart, target, etc etc)
I'm down to between 3M and Meguires.
Prinz, how come you are using 2 kinds of swirl removers? Do u use both of em at the same time or somethin. Thanks
Old Jun 11, 2003 | 07:43 PM
DanNY's Avatar
Ad·min·is·tra·tor
hmmm i don't know about their waxes..their 3M finess-it line is good stuff...same stuff shops uses.
hence i use the P21S wax instead of 3M wax.
Old Jun 12, 2003 | 07:12 PM
Bman's Avatar
I'd still try to get the Meguiar's or 3M swirl removers but Scratch-X is rumored to work too. If they're not strong enough I think Wal Mart sells 3M Rubbing Compound in the body repair section. Major chain stores usually aren't the best picks for stuff like this.
Old Jun 15, 2003 | 06:35 PM
TylerBorg's Avatar
Has anybody tried the Scratch-X??? Or for trying to get rid of scratches etc... am I best to just go with swirl remover from 3m or meguirers
Old Jun 15, 2003 | 07:39 PM
scmaxima2k's Avatar
I just detailed my car today and used scratch x on the entire car, by the time i was done though it was getting dark so I couldnt really get a good look at how well it worked. From what I could see tho, it really did a good job getting rid of swirls and scratches, Ill have a better look in the daylight tomorrow. I followed up the scratch x with meguiars show glaze then a coat of gold class wax.
-Steve
Old Jun 23, 2003 | 12:42 AM
thomasd cook's Avatar
When I first waxed my car I got bad swirl marks over the whole car. I used the Mequiar's cleaner over the whole car buffed it out and used a polish, buffed it out, then used a wax. All swirl marks were completely removed and car looked beautiful. I only do this process once a year over entire car to keep an extremely smooth finish.
Old Jun 26, 2003 | 10:27 PM
foodmanry's Avatar
Da Roller Coaster!
I've used all the products mentioned. The 3M swirl remover for dark color cars is AWESOME! Second to that one is the Meguire's swirl remover. If you want something with a combination the paint cleaner with wax works well, but the 3M is better and the Meguire's swirl remover is better as well.
The Meguire's scratch-X works well, but doesn't really last that long. It merely hides the scratches and doesn't actually get rid of them. Plus it's only meant to be applied by hand so it takes a while.
Old Jun 30, 2003 | 03:21 AM
SilverChrome03's Avatar
Try using a product like/smilar to this:
Meguiars #9 is pretty easy to use.
I've used this on my black car for the last 3 years with great results. Keep in mind that what you do after you've removed the swirls is what's really important.
Use the right tools for your car care program to make sure that you don't create more swirls every time you wash your car. Like using soft 100% cotton towels for drying, etc......
I follow up with a few coats of Meguiars Gold Class and my black car looked like it was made of black glass.
Good luck,
Bob
Old Jun 30, 2003 | 06:30 AM
endus's Avatar
An atavistic endeavor...
Meguiars Swirl Remover or Dual Action Cleaner Polish for a little more cutting power.
Old Jun 30, 2003 | 09:10 AM
How does everyone wax their car? Meaning do you use small circles to apply wax? I do not use small circles I go from front to back with almost straight lines. I've read that circles bring out swirl marks due to the angle that the car is being seen at constantly. I havbe used this method and have not had any problems with swirl marks ever again.
Old Jun 30, 2003 | 01:28 PM
Bman's Avatar
The straight line tip is a "just in case" suggestion because scratches made in straight lines (on the horizontals) are less visible than sideways scratches. The same is true but different for the vertical panels - go up and down. You don't have to if you're pretty careful about dust, but that said, that's how I do my car.
Apr 16, 2020 05:15 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
