Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
safest bug remover?
Old Aug 11, 2003 | 01:26 PM
slickrick's Avatar
safest bug remover?
i have a ton of bugs and stuff on my front bumper and on my hood where it meets the grille. what can i use that is safe enough for the paint? and should i wash my car, take off the grime, then wax my car? or should i take off the grime, wash it, then wax it?
Old Aug 11, 2003 | 02:30 PM
Y2KSESteve's Avatar
I'm pretty sure all bug removers are somewhat harsh on the paint, so I use the bug remover, wash, and then wax.
Old Aug 11, 2003 | 04:11 PM
PrinzII's Avatar
OG and counting...
Actually, you will want to do the following this order:
a) Treat bugs and tar with Bug and Tar Remover
b) Wash vehicle throughly
c) Polish vehicle
d) wax vehicle
Any tar remover is going to remove wax. You will definitely have to rewax the area.
Old Aug 11, 2003 | 04:32 PM
slickrick's Avatar
c) Polish vehicle
d) wax vehicle
what is a good polish? i used mothers carnuba wax after I wash and thats it. and how do you apply polish? the same way as wax?
Old Aug 11, 2003 | 05:32 PM
PrinzII's Avatar
OG and counting...
A good example of a polish is Klasse All In One. Polishes have some kinds of abrasive in them to reduce imperfections like swirl marks. All In one is a light polish whereas DACP is stronger than AIO because it contains more abrasives.
I also forgot a step. You might want to consider claying to get rid of some of the other contaminants lurking in your paint.
Old Aug 11, 2003 | 06:06 PM
Bman's Avatar
To clean up any (light) scratching and swirling after getting rid of the bugs, Mothers and Meguiar's both make pre-wax cleaners (really gentle) and scratch removers (a bit stronger). If you have access to 3M products or Meguiar's Mirror Glaze pro line it may be better, but in all cases with things abrasive (even mildly) they should be worked into the paint thoroughly, some until nearly dry. Laying them on like waxes won't accomplish much.
EDIT: I have a differing opinion on the order of things. Personally I would wash the car first to get rid of all the dirt and sand that may be with the bugs before you try to rub those off with bug & tar remover. Then re-wash when done.
Old Aug 12, 2003 | 12:29 AM
ch13f's Avatar
Thats what I would say also. Its always good to get rid of any loose dirt before you do anything else.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
