Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
removing waterspots
Old Sep 3, 2003 | 01:49 PM
max1ma97se's Avatar
removing waterspots
got waterspots on my black car and was wondering if i could remove it without the use of a buffer? any supplies i could buy at like pep boys or kragen?
Old Sep 3, 2003 | 07:15 PM
Dave Holmes's Avatar
A good paint cleaner (any of the step ones in a 3 step product like Meguiars Deep Crystal or Mothers), polish (like step 2 in the Meguiars Deep Crystal System), or SMR (swirl mark remover, such as Meguiars #9). All can be applied by hand to remove water spots, swirls, and oxidation. Some people will just use a cleaner-wax (those one step waxes that clean and protect), but they generally aren't as effective. Also consider using a clay bar to remove embedded contaminants (and sometimes water spots). Your end results will be far superior after a clay bar and polish/SMR.
My personal preference for surface prep is Megs #9. Works good at light swirls, oxidation, and water spots, and also contains a polish for the "wet" look. Whatever you use, be sure to apply a sealant and/or quality wax after to protect your "new" spot-free shine (such as Meguiars #26 Hi Tech Yellow Wax).
Check out www.autopia.org and also www.detailcity.com forums. They are both full of extremely knowledgeable detailers. Another new site is www.showcargarage.com by Mike Phillips from Meguiars. These sites have just about all the info you'd need to detail your car, and then some.
Keep in mind that paint prep is the most important aspect of having a really outstanding looking car. Even the best wax can not hide shoddy paint prep, but a cheap wax can protect great paint prep (even if for only a limited time).
Dave
Old Sep 5, 2003 | 09:52 PM
maximumspeed's Avatar
you can also try a solution of 50/50 distilled water and white vingar i've heard that works at removing waterspots
Old Sep 8, 2003 | 05:31 PM
Bman's Avatar
It really depends on how severe these water spots are.
Try maximumspeed's suggestion if they're just mineral deposits, or try it first, and then try some mild product like how Dave Holmes suggested (don't try them ALL though!). Come back here (or Autopia ) if those don't get you much results, as it sometimes takes stronger products...
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
