Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Question regarding tar/asphalt removal...help
Old Sep 8, 2003 | 11:53 PM
SEmy2K2go's Avatar
Go BUCKS!!!
I've had my '02 SE since Feb, and have not been too happy with the condition of the underside of the car since I bought it. Turns out my car was previously owned by Enterprise Rental. My issue is this; there is a thick coating of tar/asphalt built up inside and around the inner-fenderwells. Other than sandblasting the ****e out of it (joking), does anyone have some suggestions on removing the extra 100 pounds of build-up from my car? Thanks in advance.
-Tim
Old Sep 9, 2003 | 04:59 AM
whitedogone's Avatar
Try to remove your tires and rims and put your ride on some jack stands. Then get some paint THINNER and put some in a spray bottle. Cover the floor real good under where your working. Wet the wheel well down real good and let it soak. Wipe any overspray off the paint as you go. Keep wetting it down with the stuff untill it get soft. Then use lots of rags to clean it off. Spray some more, wipe off. You get the picture. Finish with some spray engine cleaner (watch the overspray)and a high pressure washer. It will be clean as new.
Old Sep 9, 2003 | 09:02 PM
SEmy2K2go's Avatar
Go BUCKS!!!
whitedogone,
Thanks for the assistance. Hopefully I'll get the motivation to do this when I get a few extra minutes. Thanks again,
-Tim
Old Sep 10, 2003 | 12:00 AM
nadir_s's Avatar
vicodin ... gift of life
claybar after majority of the junk has been taken off
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
