Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
damn wipers
Old May 10, 2004 | 06:25 AM
97MaximaPapi's Avatar
damn wipers
last summer i got sick of seeing the chipped paint and glare from the sun hit the wipers (not the blades) so i covered my hood and windshield, sanded them down and repainted (spray paint) They're chipped again but is there a way i can take off the entire piece? and redo them? And is there a better spray paint i should try using?
Old May 10, 2004 | 07:41 AM
CanadianMoFo's Avatar
Most wipers are attached by a small nut, and friction fit to the shaft. Try lifting the cover on the bottom of the wiper. There should be a small nut unerneath. Undo the nut. Then the wiper arms can sometimes be removed by hand by pulling straight up.
Often they are firmly attached to the shaft. I've always needed a small gear puller to pop them off. Pickup a junky one for $5 if you can.
CM.
Old May 10, 2004 | 05:25 PM
Maxima Moose's Avatar
I just painted mine recently.
Easy to get the wipers off. Remove the small cap where the wipers are attached to the car with a flat head screw driver. Take off the nut. Push down on middle of the wiper arm and pull the bottom up from the screw that is attached to the car. Really not as involved as I write it to be.
I hung the wiper arms by small strings while I sprayed them and for drying. Use a few coats of black primer on them(assuming you are painting them black). They look good with just the primer but if you are going for paint..just put a few coats of the dupli color or plasti color enamel on them. They are actually pretty shiny and my give me some glare if it is really sunny. You can clear coat them if you want also but will probably add more glare.
I hope this helps.
MM
Old May 10, 2004 | 07:03 PM
Find a flat black or semi-gloss so they're not so shiny.
stevesmax
Dec 17, 2020 11:57 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
leatherneck
Sep 30, 2015 09:16 PM
conansriver
Sep 16, 2015 12:17 PM
