When using buffer, which pads do I use for SMR and polish?
Well I have some cheap **** Turtle Wax buffer thing (don't know proper name) and I'm not sure which pads to use for what. I have blue thin ones for applying wax, some white cotton ones for removing the wax, then 2 other ones I don't know much about. One is a yellow foam pad which I *think* is for applying polish, but I'm not sure. The other is an off-yellow color which I *think* I use for after removing the wax to polish it a little bit. I can get some pics if you don't quite follow this. Thanks guys.
Usually they TELL you what each bonnet is for in the instruction booklet, don't they?
I'd be inclined to use the terry cloth bonnets for all polishing jobs. For hand polishing you'd possibly use a folded terry towel anyway. I am pretty sure the foam bonnet is for dry buffing (not recommended)
and you can probably buff off any residues by hand just as well, if not better/faster because you don't have to switch bonnets and towels won't get loaded up as fast.
Not many people seem to know about using these machines to polish because of their many limitations, and foam pad recommendations for the PC don't translate to buffers like these...
and you can probably buff off any residues by hand just as well, if not better/faster because you don't have to switch bonnets and towels won't get loaded up as fast.Not many people seem to know about using these machines to polish because of their many limitations, and foam pad recommendations for the PC don't translate to buffers like these...
Apr 16, 2020 05:15 AM
Derrick2k2SE
Nov 19, 2015 10:14 PM
bbsitum
Sep 11, 2015 04:55 PM
