Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
roof liner cleaning?
Old Dec 13, 2004 | 11:40 AM
TEEdotMAX's Avatar
my roof liner is real dirty... probably from constantly driving with the windows open. what do u use to clean the roof liner??? simple upholstery cleaner?
Old Dec 13, 2004 | 02:42 PM
infintishock's Avatar
Upholstery cleaner or warm water and extractor shampoo with a rag will work, and then it would probably be wise to vacuum it. I'd recommend using an extractor though, I think that is the best way to thoroughly, evenly and effectively clean the headliner.
Old Dec 14, 2004 | 12:59 AM
Dave Holmes's Avatar
I avoid getting mine too wet. It can cause adhesive underneath it to loosen. A damp cloth with a mild cleaner works well for me (I like Woolite and water, mixed 1 part Woolite to 6 parts water. Gentle, yet very effective cleaning for all fabrics/vinyl).
Also keep in mind that you have to clean it evenly. If not, you'll leave water spots on it. And be gentle with the fabric while vacuuming, it is pretty delicate.
If it is really nasty, an extractor (if you're lucky enough to have one) or a steam cleaner could be used. Just go slow, gentle, and avoid drenching it.
Dave
Old Dec 14, 2004 | 10:33 AM
wylie-c's Avatar
I use Windex and a rag to clean mine. Just mist it onto the headliner, wait a few seconds and then wipe it with the rag. It pulled 2 years worth of nicotine stains out of mine and looks like new. I got the tip off of a detailing site, and it does work good. Try it.
Old Dec 14, 2004 | 10:42 AM
TEEdotMAX's Avatar
thanks for the replies fellas!
Old Dec 14, 2004 | 01:29 PM
Maxima-2's Avatar
Ahhh good call brotha! I actually use aerosol window cleaner, but to each his own!
Old Dec 14, 2004 | 03:16 PM
PrinzII's Avatar
OG and counting...
I once heard of a dry clean product that works well on headliners. I need to do some research on it.
Normally, I'd take a towel and lightly spritz some carpet cleaner on it and then scrub the headliner.
I'd be about using an extractor on the headliner because the possibility of the heat or the moisture breaking down the glue.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
