Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Help; dirty mess!
Old Dec 13, 2004 | 05:18 PM
nysemt1's Avatar
Help; dirty mess!
I had to Brake really hard the other day and everything went flying including an open bottle of soda. Everything on my console got wet including my shifting gear and temperature dials. Now it's hard to shift in gear (A/T) with my car and the dial is getting really hard to turn. Should I have the stealership clean it out or can i do it myslef. Any help would be greatly appreciated
Old Dec 13, 2004 | 05:25 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Whoof - that sucks, bud. I would DEFAINATLEY DIY. A job like that will probably require that you get into the crack and creaveses, something that is not hard, but time consuming. A detail job can run around $1xx+. I'd suggest posting this in the 'DETAILING' forum, you're more likley to get the response you are looking for there.
Old Dec 13, 2004 | 05:48 PM
BlkShadow01
Just clean it yourself puss y. Take sum wipes and water and stuff.. plus you shouldn't be keepin open pop in yo car while drivin. on the second hand you shouldnt be drinkin that shi-t in the first place..noooob
Old Dec 13, 2004 | 06:02 PM
TXT-1's Avatar
What's pop?
Old Dec 13, 2004 | 06:07 PM
nysemt1's Avatar
does anybody know how i can remove the temperture console so i can get all of that stuff out???
Old Dec 13, 2004 | 06:51 PM
basictrade's Avatar
cotton swabs an alcohol would be your best tools for the job an patience
Old Dec 13, 2004 | 09:10 PM
BlkShadow01
yea but becareful using alcohol on the plastics.. they guna change colors
next time think 2wice b4 leavin an open pop in a maxi
Old Dec 13, 2004 | 10:48 PM
03tgtmaxima's Avatar
pop is soda in the midwest and canada my G/f is from IL and she fricken yells at me for calling it soda. whipes are good but i would say have it detailed if you can afford it. hell i wish i could. if not pretty much all of the above sugestions are great
Old Dec 14, 2004 | 07:11 AM
Fezzik's Avatar
Ok. I feel your best bet is to start taking things apart and using lysol to clean everything. IT has alchol in it and cuts through sugar stuff pretty good. This is somethint that would annoy the crap out of me knowing there is gunk in the shifting console and all. ITs not too hard to take it all out.
Old Dec 14, 2004 | 08:12 AM
Maxima-2's Avatar
You may want to use a steam machine on the shifter! Just don't over do it!
Old Dec 14, 2004 | 11:53 AM
Alright, first off - DON'T use alchohol. It will take the water out of the plastic leaving you with a very ugly looking peice of plastic. You do not need to use any type of solvents to get the soda cleaned other that hot water (hotter water = higher solubility) and some elbow grease. You will indeed rue the day using anything else...
As far as removing the temp control unit is concerned, you will need to remove your ashtray, followed by the shift console, then the headunit/temp control assembly. From there you will be able to disconnect the tmep control and unscrew the mounts. If you need to go as far as removing the faceplate, simply unlatch the tabs thereby exposing the button & lever assembly.
Good luck, dude...
Old Dec 15, 2004 | 04:29 AM
Sammzway's Avatar
But I suppose that a 17-year old with a Maxima grows an extra 2" below the belt because they drive a car that's an alleged "chick magnet"
hahaha.. .... that was a good one.
And for the mess, no need to go through all that hassle removing your center console just to clean, just take a thin cloth and a cotton swab, and get each and every little tiny space thats possible.. i've had coke spill on my shifter before, but i pulled over and cleaned it off right away, otherwise the sugar gets everything sticky. But like everyone said, use hot water and keep cleaning it, DEF. time consuming. Goodluck.
Old Dec 20, 2004 | 08:10 AM
AscendantMax's Avatar
those armor all wipes also pretty good at getting crap off.
Old Dec 20, 2004 | 01:36 PM
infintishock's Avatar
Armor all wipes and simple towels/rags with warm water or any other solution won't do the trick in this case. Those solutions are meant more for surface cleaning, not getting into the cracks and crevices of the dash. The best thing to use a foaming cleaner, you could probably get away with a foaming aerosol glass cleaner like Stoner's Invisible glass, but I recommend going to a supermarket or something and getting DOW/Scrubby Bubbles, the foaming cleaner for bathrooms and stuff. Also pick up a soft paint brush about an inch wide. Spray it all over the dash really saturate the cracks by the shifter, and use the brush to get it in the crevices. Use a rag to wipe off.
There will be stuff left in the cracks, so if you have an air compressor it would work wonders to get moisture out of the cracks and from behind the buttons. Blowing vacuums and cans of air will do the trick also. Foaming products are truly the best for getting in hard to reach places.
shilov
Feb 19, 2024 09:40 PM
litch
123
Jan 4, 2024 07:01 PM
spencerwh1
Jun 30, 2016 05:44 AM
carid
Sep 17, 2015 05:00 AM
