Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Wheel cleaner
Old Feb 22, 2005 | 07:36 PM
BlueC's Avatar
wat
Wheel cleaner
Will an ordinary cleaner help take off brake rust from a recently bad brake (grinded into the rotor). The wheel has bad orange/brown rust type stuff baked onto the surface. Its only one wheel.
I was thinking of maybe taking 2000grit sandpaper to the wheel, then buffing, but is there something easier that will take it off?
Old Feb 23, 2005 | 01:27 PM
BLUEMAX01SE's Avatar
if you are talking about your stock wheels , try using an s.o.s pad with hot water. i had the same problem with the 16 inch se wheels on my 97. s.o.s pad did the trick, dont worry it doesnt make it dull or anything- so you are safe for that matter. good luck
Old Feb 23, 2005 | 05:24 PM
BlueC's Avatar
wat
I will give it a try. Even if it does scratch it up, I got plenty of compounds and polish sitting around...
Old Feb 23, 2005 | 09:03 PM
Terran's Avatar
How about claying? This sounds like just the thing claying is supposed to take car of (metal that's melted its way partially into the paint). Worth a try.
Old Feb 24, 2005 | 09:38 AM
BlueC's Avatar
wat
You're right, I never thought of that. I got some spare clay bars laying around, ill try that out first.... now only if it would get above 32 degrees around here.
Old Mar 2, 2005 | 08:47 PM
xnyc's Avatar
my friend hsa something similar..brake dust burned into the clearcoat and paint on his bmw contours. tried claybar and it doesnt work..maybe brand of clay bar might affect it..
Fbana41
Aug 29, 2016 12:18 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Andy29
Sep 29, 2015 05:32 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
