Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
removing pin stripe
Old May 13, 2005 | 09:03 PM
TheGuss's Avatar
removing pin stripe
i was wondering if anybody did this. im sure many of you have. can you notice it in the paint after you take the pin stripe off. im contemplating taking my pin stripe of my max.
thanks
Old May 14, 2005 | 07:52 AM
tavarish's Avatar
fwd gone rwd cr00
yeah, i just took a hair dryer, heated up the plastic, and peeled off...it's a little time consuming, but it looks alot cleaner in the end. Also, get a bottle of goo-gone, or adhesive remover, as I did, and it cleans off all the gunk. You can notice it a little bit after you first take it off, but after a few days, it just blends in to the paint.
Old May 14, 2005 | 12:46 PM
statedog's Avatar
also, a clay bar may help too
Old May 20, 2005 | 11:27 PM
97maxblue's Avatar
I also recently removed my pin stripe I used a heat gun which is a stronger than a hair dryer, It took about an hour, but I took my time, but just be patient, Its definately worth it in the end. Good Luck
Old May 21, 2005 | 09:19 AM
godlyone's Avatar
ahhh! cliMAX!
Were any marks left?
Was the paint under the stripe darker? [because it wasnt exposed to the sun?]
Old May 21, 2005 | 04:44 PM
fmaru's Avatar
is pinstriping a factory option?
Old May 21, 2005 | 05:29 PM
TheGuss's Avatar
im def. gonna do it soon. thanks though. i will take my time.
Old May 23, 2005 | 01:04 PM
mccpu's Avatar
any one know how to remove the dealership logo on the rear of the car? mine looks like the same material as the do it yourself t-shirt imprints...
Old May 23, 2005 | 08:39 PM
mclarengts1's Avatar
any before and after picks of pin stripes removed
Old May 23, 2005 | 09:26 PM
Nismo Junkie's Avatar
any kind of sticker like that can be taken off with a heat gun, how hard it is depends on how long it was on there lol, if you have any glue left over on it just use a lil solvent or goof off type stuff and it will come right off
Old May 23, 2005 | 09:32 PM
oigs's Avatar
I removed both my pinstripe and dealer logo... it couldn't be simpler - peel the thing off! Catch one end with your fingernail (being as gentle on the paint as possible) and keep pulling, very slowly, until you get it all. I didn't need a heat gun or anything, and no scratches afterwards.
Old May 24, 2005 | 07:57 AM
98maximaSS's Avatar
i had a black stripe where i started to peel off the strip on mine so i left it alone
Old Jun 8, 2005 | 05:01 PM
Maxzilla91's Avatar
would leaving it under the sun for an afternoon make it hot enough to peel out the pin stripes easily?
Old Jun 8, 2005 | 05:07 PM
Doc's Avatar
Doc
Yes, that will definitely help make it easier. I recently took my pins off and it left absolutely no marks at all. I had a slight residue that I took off with plain rubbing aclohol. My neighbor said to stay away from the Goo Gone because it can be a little harsh on older paint. The alcohol did just fine with a little elbow grease. I then waxed it out. GL.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
