Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
overspray removal
Old May 18, 2005 | 07:27 AM
s_hinerman's Avatar
overspray removal
Hey
Bought a set of used tails and have some overspray on them. Any suggestions on how to remove it?
Old May 18, 2005 | 07:34 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Wetsand w/ +800-grit finish paper. Available @ Advance
Old May 18, 2005 | 07:36 AM
Bluesbrekr's Avatar
Doctorate in Detailing
Try a clay bar before sanding.
Old May 18, 2005 | 08:21 AM
2k2MerlotSE's Avatar
JUVIN's ride
I use clay with DT spray. Try it!
Old May 18, 2005 | 08:38 AM
jimmycapp's Avatar
Try goof off before those
Old May 18, 2005 | 08:43 AM
Deckdout2's Avatar
Play with my balls
Didn't think of that, thanks. I've got a little overspray I need to be rid of also.
Old May 18, 2005 | 11:01 AM
ChromeSE5's Avatar
brake cleaner...
Old May 18, 2005 | 12:17 PM
00SEMAX19's Avatar
brake cleaner will ruin the plastic, When I bought my car it was covered in overspray. I used rubber buffer, the kind used to clean the inside of a tire before it gets a patch. Worked great
Old May 18, 2005 | 08:12 PM
Duckman540i's Avatar
VE Powah!!!
No No, Much easier way, I redid all the black trim on my VE & was lazy on the taping on the right side & got black overspray everywhere on a White car!, including some on the windows. Just get a brand new Razor Blade & scrape it off. You want the blade to be at an angle as much as you can, cause with really sharp Razor Blades if you dont it will sometimes bite the paint, wont do any damage though if you do, I did accidentally about 5-10 times & I have (Peeling) 12 year old paint, Did Nothing. You just scrape either up or down. The blade is so sharp/thin that it will only take off the Spray Paint or whatever it is. I thought it wouldn't work till I did it & was way suprised! Works Perfectly Trust Me.
Old May 18, 2005 | 09:07 PM
xnyc's Avatar
claybar and some lubricant
Old Jun 1, 2005 | 03:27 PM
95arcticpearl's Avatar
overspray/road paint remover wipes..takes a little elbow grease to wipe them down but also be careful not to scrub too hard if using it on clearcoat
Old Jun 1, 2005 | 07:30 PM
CSVT's Avatar
you can get your hands on a buffer.. do that.. use a wool pad and meguiars diamond cut compound 2.0.. i work in a body shop and that is how we get the stuff off.. its the easiest way to do it..
Old Jun 9, 2005 | 09:38 PM
venommaxr33's Avatar
I used Black Magic Tire Shine to take overspray off mt rims. I don't know how it works but it did!!!!!
Old Jun 12, 2005 | 10:48 AM
ChromeSE5's Avatar
oops ur right lol, i was thinking of a metal piece for some reason.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
