Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
5.5 Gen Headlamp lense cleaning
Old May 28, 2005 | 01:57 PM
WHEELMAN_03_SE's Avatar
So I need some help, I washed my poor maxima for the first time in more time than i will disclose, i then proceded to claybar the entire thing, because the paint felt like sandpaper, claybar worked wonders, and a second coat of polish is curing on the surface presently. my problem is, all the exterior lacks to look perfect again is to clean the plastic headlamp lenses, I have read that glass cleaner is a NO NO, and i need badly to remove the hazy look they have, its not that noticable, except to me, so it is an issue.. Your help is greatly apprieciated. Thanks.
WHEELMAN
Old May 28, 2005 | 02:17 PM
TXT-1's Avatar
3M Plastic Polish works wonders. http://www.superiorcarcare.net/3mplaspol.html
Old May 29, 2005 | 08:37 AM
Puppetmaster's Avatar
Meguiar's PlastX....
http://www.autogeek.net/meplclplclpo.html
Old May 29, 2005 | 09:15 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Originally Posted by Puppetmaster
Good choice.
Old May 29, 2005 | 09:52 AM
PrinzII's Avatar
OG and counting...
Bear in mind, you are only polishing the outside of the lens. The "haze" is also on the inside of the lens and there isn't much you can do short of opening up the lens.
Old May 29, 2005 | 01:19 PM
Actually, the Hazy look is on the outside in this instance, You can feel it on the surface of the lense, now all i gotta do is run to the store and grab some stuff to clean it, thanks guys
WHEELMAN
Old May 29, 2005 | 01:21 PM
PrinzII's Avatar
OG and counting...
If that's the case, then Plast-X, Novus, or Renovo are the way to go.
Old May 29, 2005 | 02:43 PM
Epacy's Avatar
Unsuccesful STL Coordinator
Can it be applied by hand?
Old May 29, 2005 | 02:46 PM
SilverBelle04's Avatar
Short anwser: Yes !
Old May 29, 2005 | 02:47 PM
Epacy's Avatar
Originally Posted by SilverBelle04
Short anwser: Yes !
Does it require excessive application or rubbing in?
Old May 29, 2005 | 04:22 PM
lordkifar's Avatar
I used Meguiar's PlastX on 3 cars this weekend. First my 2K3 Maxima SE (Pride and Joy), my 97 Altima and 97 civic (not mine...I promise) and what a difference. I should have taken somepics of the cleaned versus untreated headlight. That PlastX stuff really works.
Old May 29, 2005 | 09:30 PM
dennisadhs's Avatar
Hey try toothpaste. I know it sounds crazy but I work with some old dude and this Ford Ranger he bought had hazy headlamps. He put some toothpaste on there and scrubbed it a little and bam, they looked like new again. Im not joking either.
Old May 30, 2005 | 06:31 AM
DJ2Max's Avatar
yeah toothpaste would work in some cases. some toothpast like colgate are slightly abrasive (rub it between your fingers) so they work just like plastx.
03VQMAX
Dec 7, 2015 04:59 PM
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 11, 2015 12:23 PM
soloist3
29
Sep 1, 2015 03:47 PM
