Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Specs on rim lip, what to do?
Old Jun 5, 2005 | 06:53 PM
MardiGrasMax's Avatar
I have SSR Comp/Type C with the polished lip and they have some specs in the lip. Im not sure if the lip is clear coated or polished? Should I try some cleaner wax, clay bar, paint polish, aluminum polish? What to do?
Old Jun 5, 2005 | 07:10 PM
Terran's Avatar
I'd try clay. What does it look like? Tar maybe? Everything you listed except the aluminum polish will be fine on any finish (even the aluminum polish would probably be fine).
Old Jun 6, 2005 | 05:28 AM
Bluesbrekr's Avatar
Doctorate in Detailing
I'm assuming you tried some wheel cleaner first. Then I'd go with the clay bar.
You don't want to use an agressive polish (like Mothers Mag and Aluminum Polish) if it's clear coated....and I'm betting that it is. Can you 'feel' the specs? If so you could try to carefully scrape them off with a plastic scraper.
You could try a cleaner polish like Klasse AIO. That won't scratch. Or even an over the counter 'wax', which usually contains a cleaner.
Old Jun 6, 2005 | 07:57 PM
Feels like specs, maybe tar, I'll try the cleaner wax first. Thanks!
Old Jun 6, 2005 | 10:30 PM
TsingTsaoNYC's Avatar
Can try some WD40? I used it some tar that got onto my wheels, came right off.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
Garrettz459
Sep 28, 2015 02:50 PM
