Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
mr clean
Old Aug 11, 2005 | 10:03 AM
Nissan2k5's Avatar
mr clean
hey i was wondering how is the auto dry system im thinking about buyin it but wanted to kno if anyone has used it before all answers apreciated pros and cons. thanks
Old Aug 11, 2005 | 01:11 PM
sweetlou's Avatar
I have been using this for a year now. I like it a lot.
When you use it, make sure you do each step - soak, soap, rinse, then final rinse - in sections. Try to start at the top first. As you do a new section, try not to hit the other section that is drying. almost impossible, but it makes the drying easier. I fill some water with the Mr. Clean soap in a bucket and use a bucket with a sponge during the soap application step. .
The key I think is both the soap and the filtered water. Both dry wit no spots.
Also, having the soap in the nozzle saves time. More time can be used to do the rims and tires or the inside, so I still spend about two hours doing it.
I have seen a starter kit in Pathmark for $19. The soap and filter are only good for 3 washes though. The replacements can be pricy, that is where they get you. Refill soap and filters are about $8 each. I go through about 10 washes before each needs to be replaced.
I would recommend it.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
