Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
heavy swirl and scratch removal
Old Nov 4, 2005 | 05:50 AM
MidniteMaxSE's Avatar
can anyone reccomend a product for me...ive used a lot of stuff i found in auto zone...not too much help...i hear 3m makes some good stuff but i dont know what its called...
Old Nov 4, 2005 | 11:31 PM
Street Reeper's Avatar
Handsome
Try Meguires NXT Tech Wax. My used 2k2 had the worst swirl and micro maring I had seen. I used NXT (after having great success with my 96) and it completely eliminated the swirl marks.
It is not a permanent fix but any time you wash your car you can eliminate those swirls and add a deep rich shine. Apply the nxt by hand and rubb it on and off in the direction that the wind travels over your car (back and fourth, not in a circular motion) and I'll bet it will take care of your problem.
Old Nov 5, 2005 | 09:07 AM
BlueC's Avatar
wat
It won't "take care of it". It will simply cover up part of the problem for a few weeks and the problem will return.
Go pick up some 3M Perfect-it III Rubbing Compound. It's expensive, but it'll get the job done. This is something that you COULD do by hand, but you'll get the best results with a D/A PC or Rotary. Make sure you follow up with a good polish, i'd reccomend 3M Perfect-it III Machine Glaze. Those two together will take care of your problem for good.
Old Nov 5, 2005 | 08:54 PM
street reeper i tried nxt tech wax...its pretty good but not permanent like you said....blue c where can i order this product...and what type of bonnet should i use on the buffer if i wax on by hand and want to machine it off?
thanks for the replys
Old Nov 6, 2005 | 08:16 PM
gto400no1's Avatar
i have detailed quite a few cars that were like it. my process usually consists of a medium to heavy polish with a polishing pad on my rotory and buff at 1200 rpm. after that i get some 3m swirl remover and a polishing pad on my rotory and buff. if its a dark car i have found more success using the pc for the swirl remover. i try to aviod the pc though because it takes a lot longer to use with the small pads. but i dont know what u have access to. also the tech wax... yeah dont even waste ur time or money the stuff is cr@p in my honest opinion.
Old Nov 6, 2005 | 09:24 PM
Handsome
Never said it was permanent, re-read the first line of the second paragraph.
Old Nov 26, 2005 | 06:40 AM
maxx2's Avatar
should you not use a towel when drying off your car? Is this what leads to the swirl marks?
Old Nov 26, 2005 | 07:18 AM
Terran's Avatar
You should use a QUALITY microfiber towel (waffle weave).
litch
123
Jan 4, 2024 07:01 PM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
