Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Newbie Buffer. Help please.
Old Mar 12, 2006 | 04:52 PM
BigL0U's Avatar
An aquaintance of mine refuses to help considering he use to detail cars professionally..waxing, buffing, polishing...etc.. He claims ill screw up my paint if i buy a buffer to do it myself. How hard can it be ... could you guys recommend me a model or product number for a dependable/affordable buffer? also the most commonly used products to apply on to the paint for the best possible finish? thanks. any additional info would be greatly appreciated.
Old Mar 12, 2006 | 05:49 PM
rsly33's Avatar
Porter Cable 7424 or Porter Cable 7336
With a PC, its very difficult to burn your paint, everyone can learn how to use it in no time
Sounds to me like your buddy is trying to scare you into buying a detail from him
Read the stickies to learn how to use it and what to buy
Old Mar 12, 2006 | 07:49 PM
BigL0U's Avatar
right on ... i was looking up some of those PCs on that top of the line detailing site ... anyone have other references to order such products for a good deal? also is there a major difference between the two models?
Old Mar 13, 2006 | 03:56 AM
qballjr13's Avatar
As long as the buffer you buy is a random-orbital...you can not burn your paint. You still need to be careful around corners or hard body lines since the paint is always thinner in these areas. But as long as its random-orbital you should have no problem.
Old Mar 13, 2006 | 06:02 AM
mdsmithers's Avatar
some buddy, get the Porter Cable and read up on the use, you'll be fine and find a new buddy.
Old Mar 19, 2006 | 07:05 AM
Majestic303's Avatar
Yeah, you can't go wrong with a PC! Unless you're narcoleptic and fall asleep over your car while buffing/waxing it , the chances of you burning your paint is slim. Take your time and you'll be good to go!
Old Mar 19, 2006 | 09:39 AM
BigLou93SE's Avatar
Read up in autopia-carecare.com and autopia.org. They have detailing "hot-to's" that show how to use a porter cable.
The difference between the 7336 and the 7424 is that the 7336 is packaged as a sander, while the 7424 is packaged as a polisher. The machine is the exact same, however the pad/backing plate differs. You will replace the pad anyways, as the polishing pad included in the polisher package (7424) is pure sh.t, so whichever you can get a better deal on i would go for. I bought mine from lowes.com, and it actually included the polishing pad and sanding equipment. The part number was 7336sp. A PC is very easy to use, and products are endless. Good luck.
I then also bought the Sonus DAS pads/backing plate for $50 from autopia-carcare.com, along with an asortment of polishes and products (the bill was a little pricy...)
Old Mar 20, 2006 | 06:07 PM
BigL0U's Avatar
i see ... good stuff ... i suppose ill be using the PC for the larger surfaces and just buff the edges by hand. cant be too hard. waxed my car by hand once .... never again. pain in the rear. thanks for the link BigLou ...
RinconI30
Nov 10, 2015 10:55 PM
Excalibur23
Oct 13, 2015 04:33 PM
mpbclutch33
Sep 1, 2015 09:24 AM
