Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Want to clean my engine bay
Old Jul 16, 2007 | 04:53 PM
wyche89's Avatar
Good evening orgers... I want to have my engine bay cleaned, and I was wondering what a safe way was to do it. On my old pontiac, the mechanic I went to just sprayed some engine cleaner on there and then sprayed the entire area with a high pressure hose, and it just didn't seem like the best way to do it given all the electrical connections and parts under there. Another mechanic told me that you should NEVER spray the engine bay with a high pressure hose for the same reasons I felt when my mechanic was doing it. What do you guys suggest?
Old Jul 16, 2007 | 04:55 PM
SoonerFan's Avatar
Cletus
spray down with foaming degreaser
let sit for 10 minutes
hose off
spray down with foaming tire cleaner/shiner
let dry
use towel to rub off excess
Old Jul 16, 2007 | 04:57 PM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showthread.php?t=483901
http://forums.maxima.org/showthread.php?t=402935
http://forums.maxima.org/showthread.php?t=427449
http://forums.maxima.org/showthread.php?t=31983
http://forums.maxima.org/showthread.php?t=333323
http://forums.maxima.org/showthread.php?t=259510
SoonerFan's Avatar
Cletus
Old Jul 16, 2007 | 05:26 PM
wyche89's Avatar
cool.. thanx guys... according to the other threads theres been some debate about whether or not to use high pressure water.. i think i'll play it safe and just use a garden hose with my finger in it.. so i'll cover up my battery, alternator, intake filter, fuse boxes... anything else?
Old Jul 16, 2007 | 05:27 PM
wyche89's Avatar
oh, i also didn't get a clear answer on whether to drive the car right afterwards or let it sit for a bit... what have you guys done?
Old Jul 16, 2007 | 05:28 PM
NmexMAX's Avatar
dot dot dot ...
Knock sensor valley and injector ports in front.
I usually take it for a spin a few minutes after.
Old Jul 16, 2007 | 05:35 PM
SoonerFan's Avatar
Cletus
yeah, drive it afterwards. the heat will help dry and the movement will prevent water from collecting anywhere
Old Jul 16, 2007 | 05:44 PM
wyche89's Avatar
makes sense... both of you guys have alot of posts, so i assume you know what you're talking about.. lol
Old Jul 16, 2007 | 05:45 PM
wyche89's Avatar
can you describe to be where those things are?
Old Jul 17, 2007 | 06:12 AM
NmexMAX's Avatar
dot dot dot ...
Even if puddles collect, if you drive it a little afterward, those areas I mentioned should dry out rather quickly, so there really is not need to worry about much if anything aside from the obvious (intake)
Old Jul 17, 2007 | 10:15 AM
bigEL's Avatar
These guys, yes. But you can't always tell because a lot of other guys spew cr@p just to boost their post count.
Old Jul 17, 2007 | 10:29 AM
Bufflomike's Avatar
Sexier Than Simpson
the Friday Washington DC thread comes to mind
Old Jul 17, 2007 | 10:34 AM
NmexMAX's Avatar
dot dot dot ...
Join date > * ..
It doesn't matter post count/join date. Knowledge > * .. . Some guys on here know way more than me and haven't been here that long, same goes w/ PC.
Old Jul 17, 2007 | 07:50 PM
DJ2Max's Avatar
just cover up the electricals and you should be safe. Let us know how it turns out!
Old Jul 17, 2007 | 08:43 PM
wyche89's Avatar
i will... i'll probably do it tomorrow after i wash the car.. i would take pics, but i dont have a digital camera
Old Jul 18, 2007 | 05:39 AM
Puppetmaster's Avatar
but I'm moving it to Detailing.
Old Jul 18, 2007 | 06:55 AM
Anachronism's Avatar
Spray with simple green, let soak, rinse, spray with self cleaning tire foam. Ten minutes work and a huge improvement if your engine bay has been neglected. I only use a garden hose, don't cover anything and have never had a problem. I use my shop vac to blow things dry, the air is filtered so there is no chance of blowing a small pebble at your car at 200MPH
Before
After
If you really want it to look good you need to spend a little more time with armor all, metal polish, and a rag.
Old Jul 18, 2007 | 07:29 AM
devmax5's Avatar
I use simple green myself also, works pretty good. I usually only cover up the battery and altenator with plastic wrap
6spd4dsc
Mar 4, 2016 05:19 PM
Maximan190
Dec 16, 2015 06:01 AM
fastcarny
Oct 6, 2015 10:42 AM
aminus21
Sep 12, 2015 04:53 PM
03VQMAX
Sep 5, 2015 03:47 PM
