Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
removed pinstripe, now what???
Old Oct 20, 2007 | 02:20 PM
max ride 41's Avatar
so i remove thr pinstripe and its left marks on the paint and scratches. i tried cleaner wax and waxing it after i did it to no avail, still can see where the stripe was. any way of safely removing the marks???? its a 95 btw, and it allready has 10 billion little scratches. thanks>>>>> here's a pic..
Old Oct 20, 2007 | 06:21 PM
spdfreak's Avatar
I would say, use a clay bar, but don't blame me if it screws something up.
Don't forget, that just like if you have a picture frame on a wall for years, and remove it, the paint behind it will be cleaner, and usually differant in color since it was protected from the elements.
Let us know what happens.
Old Oct 21, 2007 | 12:42 AM
95 Maxnout's Avatar
Yep,same thing happened to me when I removed mine off my 95.I waxed it a couple of times on the same area that the pinstripe was at and you could still see where it originally was.It will fade out over time as the weather and elements hit it.By the way,it looks 100x better w/o the pinstripe.
Old Oct 21, 2007 | 04:28 AM
i tried the clay and i did'nt do squat, i think its just old and its like some marks i had on a window of an old toyota i had that had stickers, time and the elements left an indelable mark that aint going away completly. i'l mess around with it with compound a little but not too much. thanks again for the compliment, i think it looks better as well.
Old Oct 21, 2007 | 07:43 AM
defdwight's Avatar
Maxima Newb
I've removed pinstripes from tons of cars and I do it the same way each time. I'm not sure if you have leftover adhesive residue, but if you do, try this:
Get a rag and some lacquer thinner. Put some lacquer thinner on a small portion of the rag and *gently* rub the leftover adhesive. The key is doing this gently, it takes a while but works. You'll have to keep using different parts of the rag because the adhesive builds up quickly and you want to keep the rubbing surface clean.
After all the adhesive is completely removed (this could take a couple of hours depending on how much adhesive residue is on the car), clean along where the pinstriping was with soap and water. Get some high quality wax like Meguiar's Tech Wax (what I use) and give the pinstriping area a serious buff. Usually 2-3 coats along the area is what I do.
This technique has worked for me on at least 10 cars, some of which had ridiculous amounts of residue left over from pinstripe removal. Hope it helps.
Old Oct 21, 2007 | 03:40 PM
MOHFpro90's Avatar
I was under the impression that lacquer thinner, paint thinner, etc, was not good for paint, even sparingly?
Old Oct 22, 2007 | 06:02 AM
yeah, there's no way i'd use laquer thinner on 12 year old paint. i'm gonna try more goof off and some rubbing compound and if it still leaves a mark oh well.
Old Oct 22, 2007 | 07:41 AM
!PrjctMax!'s Avatar
True, but Bug&Tar is safe to use, just in small amounts and without pressing/rubbing on the same area for too long.
You can do that and try using a buffer with that compound, and then finish off with some sort of wax/sealant
Old Oct 22, 2007 | 02:10 PM
defdwight's Avatar
Maxima Newb
Actually, it's used a lot in auto detailing. It's a great solvent for removing tough contaminants from paint. The trick is to be discrete with it and you won't damage the finish. And you ALWAYS want to give the treated area a good waxing afterwards because the lacquer thinner will remove any protectants that are on the paint surface.
I use lacquer thinner to remove pinstripe adhesive every time I remove pinstriping from a vehicle.
Old Oct 22, 2007 | 02:14 PM
defdwight's Avatar
Maxima Newb
Unless your paint hasn't dried yet , you really wouldn't have anything to worry about. Of course, you don't want to vigorously scrub with it, as you could mar up the finish that way. Luckily, it takes little effort to remove adhesive that way.
FWIW, here's a pic of my car that I took right after removing the pinstriping using the exact method I described to you. I did it on Saturday. The paint is 10 years old.
Just trying to save you some time, effort, and aggravation.
Old Oct 22, 2007 | 08:30 PM
your paints in much better condition than mine, i detailed sprayed it today and did'nt notice any major areas except of course the drivers door!!! damnit.....
Old Oct 23, 2007 | 06:09 AM
maximized98's Avatar
Addicted to the Org
Grab some 3m adhesive remover. It works great on that kind of stuff. I used it when I debadged and removed the pin stripes. You can still see if you really look where my pinstripes used to be, but I think the sun will blend it in better over time.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
