Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Rotary buffer: 7" cutting/polishing pads?
Old Apr 21, 2008 | 01:22 PM
MOHFpro90's Avatar
I have a rotary buffer that I have used before with a simple foam pad to apply/remove wax on my car, and the Sienna. However, I am looking for some good 7inch foam pads for cutting, polishing etc. I checked the sites in the sticky, however all of them are either 6.5" or 7.5" and I dont want to spend $10/pad and have them not fit.
Also, if I wanted to get a new backing pad, what would you guys suggest? Would it be better to get a new backing pad, and a set of foam pads that I know will fit?
I will be practicing on a dark green hood to get a feel for the buffer.
Thanks in advance.
Old Apr 24, 2008 | 04:58 PM
MOHFpro90's Avatar
Anyone gonna help me?
Old Apr 24, 2008 | 06:22 PM
95maxrider's Avatar
Lightly modded
It might help if we knew what model buffer you use....
Old Apr 24, 2008 | 07:48 PM
MOHFpro90's Avatar
Its a black and decker 9531. Not made any more, not sure how old it is, but it runs well(brushes in motor are ok, commutator and winds good too). 2100/2500rpm low/hi.
Old Apr 25, 2008 | 09:39 AM
Double0GLE's Avatar
Rotary = Orbital? If so, you can't really get any scratches out with those, I suppose to you could, but to get a scratch out you do know that you're cutting clear using heat and the orbital doesn't get hot even to cut. But I suppose you could but I wouldn't..
Old Apr 25, 2008 | 10:15 AM
Scottwax's Avatar
That's Mr. Detail to you
No idea if today's backing plates would work with that model buffer. The ones now allow you to quickly attach velcro backed pads to them.
Old Apr 25, 2008 | 09:27 PM
MOHFpro90's Avatar
Scott,
Thanks for the reply. Ive been looking at a cyclo polisher(what you have in your avatar correct?) also. Although not cheap, they look awesome and any pad you need is available. Would you recommend it?
Old Apr 25, 2008 | 09:32 PM
clayman88's Avatar
Huh?
Old Apr 27, 2008 | 10:46 AM
Scottwax's Avatar
Originally Posted by MOHFpro90
Scott,
The Cyclo is pretty good, especially if you switch it over to the Edge system which perfectly centers the pad. The Flex 3401 would probably be better though, more power (thought not quite as much as a rotary) and easier to use on cars with lots of curves.
http://www.detailedimage.com/Flex-M2...FQIegQod2UJdxw
Old Apr 27, 2008 | 10:48 PM
MOHFpro90's Avatar
Scott, I wish I could afford something like that. I am looking at the ~$150 or under range, and I found a few cyclo's (used of course) for just under that. The 7424 is always an option too. Are there any others you recommend on my budget?
Old Apr 28, 2008 | 08:04 AM
95maxrider's Avatar
Lightly modded
There's always the Ultimate Detailing Machine. I love mine.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
05RLS2
Sep 27, 2015 09:24 PM
bbsitum
Sep 11, 2015 04:55 PM
