Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
has any one seen this vid
Old Apr 14, 2012 | 12:28 PM
Kountz430's Avatar
bald aggression est 78
i stumbled upon this detailing vid, previous to find i was wondering how to wet sand i think its a good informational vid http://www.youtube.com/watch?v=QuYGt...feature=relmfu pt2 http://www.youtube.com/watch? NR=1&f...&v=v8PvDksGSZw pt3
http://www.youtube.com/watch?v=_EMZJ...feature=relmfu
Old Apr 17, 2012 | 07:51 AM
pimpin02max's Avatar
Well first you need to ask yourself...are you wanting to wetsand to get rid of some orange peel or some surface scratches? If you want to make the job easy 3M has the trizact 3000 pad for a DA (dual action sander) and if you want to get rid of some peel I would take a soft flexible block with 2000grit paper, be gentle as most factory paint it is easy to sand through the clear especially on curves. Then run the trizact over the top of that. Then assuming you have a good buffer I would use either the Meguiars or 3M 3 step system (compound, polish, ultrafine polish if on dark colored car) also make sure you have the right pads for the job on your buffer. Wetsanding is not as complicated as a lot of people make it out to be it's just time consuming and you need to make sure you have the right tools/products if you really want high quality results.
AaronL
Aug 8, 2020 10:31 AM
bennuss
Sep 11, 2015 05:55 AM
maximumsportZ
Sep 21, 2002 10:15 AM
Sprint
Aug 29, 2001 09:11 AM
