Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Best way to dyno a auto
Old Nov 30, 2002 | 05:07 PM
MyownNismo's Avatar
Future Camaro SS owner
I had just gotten my 1st dyno done on my 2000 maxima se and was wondering what's the best way to dyno the car. Do you want to keep it in 2nd gear, 3rd gear, or have overdrive off. Reason why I am asking is my dyno was kinda weird and want to know have you run an auto on a dyno so when I get my y-pipe I will get a better dyno result. Here is my last dyno and the dynorun. 001 the torque is wrong since it spiked at the end of the run.
http://images.cardomain.com/installs...17_37_full.jpg
Old Nov 30, 2002 | 05:24 PM
mtrai760's Avatar
'Trynna' is not a word
Auto's should be dyno'ed in 3rd gear.
Old Nov 30, 2002 | 06:26 PM
MyownNismo's Avatar
Well how are you supposs to keep it in 3rd gear. Mine goes 1st 2nd then drive. Would it stay in 3rd with overdrive off.
Old Nov 30, 2002 | 06:55 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
To get a solid dyno in 3rd gear, what you need to do is get the car up to a steady speed on the dyno in Drive (O/D Off) such that when you punch it, it won't downshift to 2nd gear. I think this is probably around 70-75 mph or so. Then just take it all the way up to the rev limiter.
Old Nov 30, 2002 | 07:22 PM
MyownNismo's Avatar
Thanks I will remember that for the next time.
Old Dec 1, 2002 | 03:25 PM
Synki's Avatar
3rd gear for the auto.
You want the closest 1:1 ratio as possible.
Old Dec 2, 2002 | 04:44 AM
SteVTEC's Avatar
Originally posted by slammed95
So autos can't dyno thru the whole rpm range?
My Accord V6 had a winter start mode where if you put it into 2nd, it would just stay there no matter what. So you could get a dyno of the entire rev range, but only in 2nd gear. Not as accurate, but sometimes relative gains/losses are more important than all-out accuracy when testing mods.
I don't know if the Maxima's automatic does this or not.
Old Dec 2, 2002 | 08:32 AM
MyownNismo's Avatar
When they dynoed my car I had my rsm running and it said 167 for HP. There is a way to find out your HP with the RSM and I did what you said run up to 70-75mph on the road then punched it and it went all the way to the rev limiter then shifted to fourth and that's how I got 167. What do you have to do to get your dyno SAE corrected.
Old Dec 2, 2002 | 10:26 PM
CandiMan's Avatar
Say Candyman 5 times
Exactly
Originally posted by SteVTEC To get a solid dyno in 3rd gear, what you need to do is get the car up to a steady speed on the dyno in Drive (O/D Off) such that when you punch it, it won't downshift to 2nd gear. I think this is probably around 70-75 mph or so. Then just take it all the way up to the rev limiter.
My advice try doing some 3rd gear pulling on the hwy so you know exactly what speed you have to be going in-order for the tranny not to down shift to 2nd when floored. Even though it will work I believe 70-75 may be too high. Try cruising on the hwy with the o/d off at about 50-55 and punch it to see if the tranny down shift. If it does go up in 5 mph increments until you find that speed where the tranny will not down shift. Remember what that speed and you're set for your pulls on hte dyno. When I dyno mine, I also turn on the heat and put the fan motor at the 3rd position so not to put too much amp draw on the alternator. This might help with the engine cooling especially if they have a fan in front of the car.
Old Dec 3, 2002 | 02:10 AM
Larrio's Avatar
The Definitive AE Master
Re: Exactly
for my 2k1, I found that anything higher than 65 mph will be a third gear pull. Anything less goes into second when you punch it.
just tested this yesterday night
Old Dec 6, 2002 | 10:32 PM
chi02max's Avatar
for the 2k2's.... can't you just leave it on 3? o wait.. nevermind... or wait.. yea.. leave it on 3... and slowly rev it up to 6600 rpm right??? press on the gas hard enough where it won't shift to OD. like half throttle?? won't that work? cuz i dynoed my car on 2nd gear... and was not satisfied.... IMO, leave it in third, you should be going around 35 mph? then gradually step on the gas. and about 4400 rpm, go about 3-4 throttle?? i dunno... ive been working on this for awhile... im not sure if this will work... but im sure it will still be on 3rd gear, as long as it doesn't downshift or upshift?? does anyone agree?? or disagree??
Old Dec 12, 2002 | 10:58 AM
glowworm_76039's Avatar
third gear trickery
don't know if the same is true for 2000, but when I disconnected the speedometer sensor on my '92, it disabled the detent(upshift) function on the tranny, causing it to stay in whatever gear was selected...?
AaronL
Aug 8, 2020 10:31 AM
hayne
Oct 5, 2015 11:53 AM
Maximeltman
Sep 28, 2015 07:19 PM
dshinn
Sep 26, 2015 08:07 PM
